[pgrouting-dev] Possible design flaw in TSP general methods
Dave Potts
dave.potts at pinan.co.uk
Tue Aug 6 14:35:14 PDT 2013
On 06/08/13 23:20, Stephen Woodbridge wrote:
> On 8/6/2013 5:17 PM, Dave Potts wrote:
>> If I have a distance matrix which looks like
>> 0 4 9999 1
>> 4 0 2 3
>> 9999 2 0 2
>> 1 3 2 0
>> The idea being that the only cheap route from 3-4 is to 3-4 and then
>> 4-3 to get back, but if naviating a path for the entire tsp, it never
>> calls back on it self, so it would assume that the entire problem can be
>> solved in 4 hops, when the best possible route will be in 5 hops.
>> Starting at 1
>> For example 1-> 2 2->3 3->4 4->3 3->1, total 11 Total 5 interconnecting
>> nodes
>> 1->4 4->3 3->1 total 9999+3+3 total 10005 Total 4
>> interconnecting nodes, but rather more expensive
>> Does anybody know of a tsp method that can resolve something like this
>> and what its called? I am looking for a tsp that does not mind double
>> back on itself.
> This is called TSPM or TSP "Multiple Visits" if you google it. I have
> seen a reference to being able to convert this problem into a standard
> TSP problem similar to the ATSP to TSP solution.
> -Steve
Thanks Steve, if wonder if such a thing as Multiple Visits asymmetric
travelling salesman problem solution exists
Dave.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
