[pgrouting-dev] Schema Handling
Stephen Woodbridge woodbri at swoodbridge.com
Fri Aug 23 11:34:44 PDT 2013
On 8/23/2013 12:48 PM, Vicky Vergara wrote:
> <https://github.com/cvvergara/pgrouting/tree/develop><https://github.com/cvvergara/pgrouting/tree/develop>https://github.com/cvvergara/pgrouting/tree/develop
> I created a pull request for the schema handling problem.  Issue 178
> Can you give it a try and report any problems?
> It has a lot of NOTICES  to inform the status of the process, to help
> pin point any problem you encounter.
I have created a branch in pgrouting cvvergara-issue178 where I merged
vivky's pull request and fixed a few minor problems. It might be easier
for most users to:
 From the pgrouting directory:
git pull
git checkout cvvergara-issue178
And work this that code to test her changes.
-Steve
More information about the pgrouting-dev mailing list
