[pgrouting-dev] [pgRouting/pgrouting] 2d7e98: update some functions
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Aug 23 12:52:13 PDT 2013
Hi Razequl,
Thank you for checking your code. I just had a "quick" look over it and
you seem to be making good progress. I see you are starting to integrate
you code into pgRouting. Is it safe to assume that you have it working
to your satisfaction in yout tester environment?
One issue that we have run into with out pgrouting code is that you
should not push_back large objects on to a std::vector as this seems to
allocate memory for a copy and it tends to fail. We have worked around
this in other code by pushing a reference or point onto the std::vector
an then making sure we new() and delete() the objects as appropriate.
These seems to work fine outside the postgresql environment, but tends
to be problematic in postgresql and it seems to be random whether it
works or not.
So just keep this in mind as you are integrating code.
Thanks,
-Steve
On 8/23/2013 3:25 PM, zibon wrote:
> Branch: refs/heads/gsoc-vrp
> Home: https://github.com/pgRouting/pgrouting
> Commit: 2d7e9858d029d0fbbc41003336217b0490edb437
> https://github.com/pgRouting/pgrouting/commit/2d7e9858d029d0fbbc41003336217b0490edb437
> Author: zibon <ziboncsedu at gmail.com>
> Date: 2013-08-23 (Fri, 23 Aug 2013)
> Changed paths:
> M src/vrp_basic/src/VRP_Solver.cpp
> M src/vrp_basic/src/VRP_Solver.h
> Log Message:
More information about the pgrouting-dev
