[pgrouting-dev] Witch dev branch to use
Daniel Kastl
daniel at georepublic.de
Mon Aug 26 12:31:32 PDT 2013
On Tue, Aug 27, 2013 at 4:06 AM, Dave Potts <dave.potts at pinan.co.uk> wrote:
> The page http://docs.pgrouting.org/dev/**doc/src/installation/index.**
> html#build-from-source<http://docs.pgrouting.org/dev/doc/src/installation/index.html#build-from-source>,
> lists 5 different branches, if I want to do some development work, which
> one should I use?
Hi Dave,
These are not different branches but tags, that can be downloaded.
If you want to develop, then you best clone the Git repository and use
branch "develop". There is only one of this name.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130827/4fb98a0e/attachment.html>
More information about the pgrouting-dev
