[pgrouting-dev] K shortest paths for pgroute[New code]
Dave Potts
dave.potts at pinan.co.uk
Sun Jan 13 09:21:18 PST 2013
Hi List
I have added a section of code to the pgroute source archive for working
out the K shortest paths on a postgis database.(git path is dapotts)
The base KSP code is taken from
http://code.google.com/p/k-shortest-paths/source
My only contribution is the interface between this c++ code and pgroute
software
Dave
Included README
My working environment is
Test machine ubuntoo 12-04
install postgres 9.1
install postgis 2.0
install liboost-ranom 1.48
built on box CGAL-4.1
gaul 0.1850
IT HAS NOT BEEN TESTED or build on a windoz machine
regards
Install
cmake -DWITH_TSP=ON -DWITH_DD=ON -DWITH_KSP=ON DebugFull .
make install
psql -d data-base -f /usr/share/postlbs/routing_ksp.sql
psql -d data-base -f /usr/share/postlbs/routing_ksp_wrappers.sql
Note the first time its used its will complain about a missing type,
this error can be ignored
(Text is off the form
psql:/usr/share/postlbs/routing_ksp_wrappers.sql:25: ERROR: function
ksp_sp(character varying, character varying, integer, integer, integer,
boolean) does not exist
psql:/usr/share/postlbs/routing_ksp_wrappers.sql:26: ERROR: type
"ksp_geoms" does not exist
Where data-base is a spatial database of your choice
KSP code base taken from
Checkout is svn checkout
http://k-shortest-paths.googlecode.com/svn/trunk/ k-shortest-paths-read-only
See directory test for an example of use
Setup the code expects to find a table that defines a series on vertexs
and nodes
The format is
create table network (
gid serial NOT NULL,
source integer NOT NULL,
target integer NOT NULL,
cost float,
reverse_cost float
the_geom
The table can be called anything, must includes the fields
gid,source,target,cost and reverse_cost, an example is provided in the test
directory.
Where
gid is a unquie value
source is source vertext
target is target vertext
cost is the 'cost' of getting from source to target
reverse_cost is the 'cost' of getting back from source to target
the_geom a MULTIlINESTRING geometry that describes the route
between source and target, it may be null
Is only used if asked for get generating the routes
The code is invoked as
ksp_sp(sql string,name of table ',start,end,number of routes
,include the reverse cost)
eg
ksp_sp('select source,target,cost,reverse_cost,gid from
network','network',4,5,15,'f')
Where sql string must provide the
source,target,cost,reverse_cost and gid from the data table
name of table the name of the table to be used.
start the starting node.
end the ending node.
number of routes the number of routes to generate.
include reverse cost include the reverse cost values when
generating results.
The returns values is a list of link segments that describes the given
route, in the format
id,
route_id
edge_id,
the_geom
id refers to the current result set
edge_id refers to the gid in the supply table
route_id refers to the current route
the_geom refers to the geometry in the supply table
eg.
id | edge_id | route_id
| the_geom
0 | 15 | 0 |
0105000020110F0000010000000102000000020000000000000000001040000000000000104000000000000010400000000000001840
1 | 13 | 1 |
0105000020110F0000010000000102000000020000000000000000001040000000000000104000000000000008400000000000000840
2 | 10 | 1 |
0105000020110F0000010000000102000000020000000000000000000840000000000000084000000000000000000000000000000000
3 | 2 | 1 |
0105000020110F0000010000000102000000020000000000000000000000000000000000000000000000000000400000000000000040
4 | 9 | 1 |
0105000020110F0000010000000102000000020000000000000000000040000000000000004000000000000010400000000000001840
5 | 13 | 2 |
6 | 10 | 2 |
7 | 1 | 2 |
0105000020110F00000100000001020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F
8 | 5 | 2 |
0105000020110F000001000000010200000002000000000000000000F03F000000000000F03F00000000000000400000000000000040
9 | 9 | 2 |
This set of results descrbes 3 results 0 of one hop, 1 of 4 hops, 2 of
5 hops
More information about the pgrouting-dev
