[pgrouting-dev] Fixes for Bidirectional code just checked in
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 4 19:10:24 PDT 2013
Daniel,
Thanks, I just added some more content to that.
-Steve
On 6/4/2013 9:48 PM, Daniel Kastl wrote:
> On Wed, Jun 5, 2013 at 5:34 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> On 6/4/2013 3:53 PM, Alec Gosse wrote:
> Hello,
> I've just pulled from the develop branch and built fresh and I'm
> getting a server crash from pgr_bdastar. If I run exactly the same
> thing using pgr_astar, it works. This is using postgres 9.2.4 and
> postgis 2.0.3 from Homebrew on Mac 10.8.3
> I'm using pg9.2.4 and postgis 2.0.x or 2.1.0beta3dev and I fixed
> these issues I thought. Evidently not.
> I'm still working on a bulk routing function using bdastar, but just
> realized that the regular version was crashing without my
> modifications. I'm happy to try to track this down, but have little
> knowledge of how to debug within postgresql. Any pointers would be
> appreciated.
> OK, start by uncommenting #define DEBUG 1 in both the C and C++
> code. Then add more DBG('I got here message\n"). In the C++ code
> these messages get written to a file '/tmp/sew-debug' and you can do
> a tail -f on that in another window to see your progress.
> This is likely a issue in the C++ code but it may also be something
> systemic about the way we are integrating code. If you build your
> own postgresql you might want to rebuild it with --enable-cassert
> option to configure which will put the database backend into a more
> rigorous memory check mode.
> That is a start, I would be appy to help more if I can.
> Hi Steve,
> I have started a Wiki page to collect that kind of information, because
> that's easier to find someday than a years old email thread:
> https://github.com/pgRouting/pgrouting/wiki/Developer---How-to-debug
> I have copied there a few collected notes.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
