[pgrouting-dev] GSoC Students
Razequl Islam
ziboncsedu at gmail.com
Wed Jun 5 03:50:10 PDT 2013
Hi Steve,
Thank you very much for your detailed suggestion on code management and
git. I just sent Daniel a mail on it.I will follow them and let you know if
I find any difficulties.
I just read over the mails on the crashing thread. I should have done
better. It is a good practice to initialize the vector size beforehand when
we are working with std vectors. I am sorry for the inconvenience caused. I
hope all is working well now. In any case I will review the codes and check
if there are more pitfalls in it.
Thanks for your support. It is always a great experience to work with you.
And Mukul, congratulations and welcome to the community. I am sure you will
enjoy the summer.
-Razequl
On Tue, Jun 4, 2013 at 12:56 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Razequl,
> Great to have you back again. This is the community bonding time so it
> would be good to start outlining your thoughts on your project, geting the
> development sort out again which you are working.
> Daniel already mentioned the you need to work with branch "develop" and
> not "sew-devel-2_0", I think you already have a github account, you should
> fork pgrouting from the github page.
> Then do:
> # create a local branch to do your work in
> git checkout -b vrp-project develop
> mkdir -p src/vrp/src src/vrp/sql src/vrp/doc src/vrp/test
> touch src/vrp/src/CMakeLists.txt src/vrp/sql/CMakeLists.txt
> src/vrp/doc/CMakeLists.txt src/vrp/test/CMakeLists.txt
> git add src/vrp/src/CMakeLists.txt src/vrp/sql/CMakeLists.txt
> git commit -m "Create initial directory structure for VRP project."
> # push you local branch back to your fork
> git push -u origin vrp-project
> This will create the initial structure for you project in our source tree,
> look at the CMakeLists.txt files in the ksp or bi-directional tree
> structure and clone this for your project. I would create a simple "Hello
> world" app in your vrp tree to work out the issue. Ask if something is not
> clear.
> Now you can create files, add them to your project, commit them locally,
> push them back to your fork etc.
> # create or edit files vrp.cpp ...
> git add vrp.cpp ...
> git commit -m "Adding vrp.cpp ..."
> git push
> These last 3 commands will allow you to back up your changes to the github
> so if you loose your laptop of the disk crashes, etc all you code will be
> saved on github. We can also review, comment, and help if you need it,
> because we can access your files from github also.
> When we are ready to merge VRP in the pgrouting core project, it will be
> easy for me or Daniel to pull your code and merge it.
> One more piece of good news is the fact that I think I resolved the server
> crash issues in the bi-direction. If you have questions on that ask, I sent
> you an email on it. Also notice that all C++ code needs a try-catch
> exceptions wrapper around it. Look in the bi-directional code to see that.
> Also, I'm moving this to the -dev list so Mukul Priya can also benefit
> from this discussion as he is our other GSoC student this year.
> Mukul, likewise you should do the same for your project.
> Best regards,
> -Steve
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130605/890a724d/attachment-0001.html>
More information about the pgrouting-dev
