[pgrouting-dev] Having problems under standing the distance matrix of TSP in respect to route network pgroute version 2
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jun 14 06:07:03 PDT 2013
Hi Dave,
I'm not totally opposed to this, but I would like to discuss how you
plan to structure the data and what your query would look like.
There is another possibility that I like better and that would be to
write stored procedure that takes you sql query and returns a matrix.
matrix[][] pgr_matrix(sql text)
Then you can do something like:
select * from pgr_tsp(pgr_matrix('select * from matrix_table'), 27);
This is like to be reusable elsewhere as a utility.
-Steve
On 6/14/2013 1:38 AM, Daniel Kastl wrote:
> Hi Dave,
> Somehow we already discussed this in May:
> http://pgrouting.974090.n3.nabble.com/pgrouting-dev-New-TSP-API-td4025094.html
> I think the current function pgr_tsp function is good as it is, but some
> alternative with SQL query is a good idea.
> Then there would be two ways how to call TSP, for example
> pgr_tsp(matrix float[][], start integer)
> pgr_tsp(sql text, start integer)
> But instead of rewriting it's better to write a wrapper function that
> accepts SQL and transforms it into the matrix (and ensures that the
> matrix is valid).
> Daniel
> On Fri, Jun 14, 2013 at 2:17 PM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
>     On 14/06/13 02:59, Daniel Kastl wrote:
>     Hi Daniel, List
>     I must admit I found the entire process of creating a postgress
>     array in a suitable form for the pgr_tsp function to be a exercise
>     in slow torture!
>     Would anybody have any major objections if I attempted to rewrite
>     the interface so it took a normal sql querry?
>     Something like
>     pgr_costResult[]pgr_tsp('SELECT source,target distance FROM vertex_table',2);
>     That way the problem with creating a square array in postgres would disappear.
>     Dave
>     <https://www.google.nl/search?client=ubuntu&hs=uQi&channel=fs&gl=uk&q=exercise+in+slow+torture&spell=1&sa=X&ei=BKa6UYnAF5G20QXc_4HQCg&ved=0CCcQvwUoAA>
>>     Hi Dave,
>>     Thanks for reporting. Maybe I just mixed up something with copy &
>>     paste.
>>     I remember that I needed to add a vertex table to the sample data
>>     for the new TSP with distance matrix and got the ID's a bit wrong
>>     first.
>>     Will take a look.
>>     Daniel
>>     On Fri, Jun 14, 2013 at 7:40 AM, Stephen Woodbridge
>>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>         Dave - moving this over to the pgrouting list.
>>         Hi Dave,
>>         I'm not sure the Daniel used the example data network for this
>>         example. The data looks like one of the matrix I used in my
>>         test cases.
>>         src/tsp/test/*.test
>>         I just made up numbers for a symmetric matrix. It was not
>>         taken from an actual network.
>>         So the sly part is that its NOT from a graph ;)
>>         Daniel - please correct me it you did something else.
>>         -Steve
>>         On 6/13/2013 6:11 PM, Dave Potts wrote:
>>             In the travel sales person problem an example is provided,
>>              I having
>>             problems understanding it
>>             The example route network is posted as
>>             http://docs.pgrouting.org/dev/doc/src/developer/sampledata.html#sampledata
>>             I have assume the distance between red node 1 and red node
>>             3 is 2, ie
>>             the unit distance 1 +1  which I  make to be 2
>>             given that
>>             I think the route matrix should be
>>                  1 2 3 4
>>             1 | 0 1 2 3
>>             2 | 1 0 1 2
>>             3 | 2 1 0 1
>>             4 | 3 2 1 0
>>             distance 1 to 4 is 1+1 +1 ==3
>>             distance 2 to 4 is 1+1       ==2
>>             distance 3 to 4 is 1
>>             etc
>>             But the give value is (please see
>>             http://docs.pgrouting.org/dev/src/tsp/doc/index.html)
>>                  1 2 3 4
>>             1  {0,1,2,3},
>>             2  {1,0,3,2},
>>             3  {2,3,0,4},
>>             4  {3,2,4,0}
>>             I just don't understand how the distance between 3 and 4
>>             can be the
>>             value 4, ditto he values between 2 and 3
>>             Have I missed something sly ?
>>             Dave.
>>             _______________________________________________
>>             postgis-devel mailing list
>>             postgis-devel at lists.osgeo.org
>>             <mailto:postgis-devel at lists.osgeo.org>
>>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>         pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org
>>         <mailto:pgrouting-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>     Georepublic UG & Georepublic Japan
>>     eMail: daniel.kastl at georepublic.de
>>     <mailto:daniel.kastl at georepublic.de>
>>     Web: http://georepublic.de <http://georepublic.de/>
>>     pgrouting-dev at lists.osgeo.org  <mailto:pgrouting-dev at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
More information about the pgrouting-dev mailing list
