[pgrouting-dev] Having problems under standing the distance matrix of TSP in respect to route network pgroute version 2, possible solution
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 15 12:45:27 PDT 2013
On 6/15/2013 2:34 PM, Dave Potts wrote:
> On 15/06/13 14:28, Stephen Woodbridge wrote:
> Nice Idea, but one of the problems I have is that I am VERY lazy!
> When I create a source/target/cost table I only tend to populate it with
> existing routes, so if I have path at cost of 42 betweens nodes 2 and 3
> I will create an entry like
> 2 3 42
> I have no desire to create an entry for journey between nodes 5 6 that
> does not exist or having to provide a value for journey between myself
> and myself eg a journey from node 2 to node 2, I think the suggested
> solution would require me to create entries like
> 2 2 0
> 5 6 0 etc
> So I had a crack at writing a function based on Steves original
> screenplay. I think it needs a lot more work, when I create the
> temporary tables, I get a diagnostic from psql saying that its created
> a table. There must be a better way of doing it
> Its invoked as
> select mktsparray(' select source,target ,cost from edge_table2');
> -- Make a distance matrix for the traveling salesman problem
> -- Input is an sql string that provides source, target and the cost
> -- of getting between them
Dave,
You have to do the work somewhere ;) Either in the table entries or when
you initial the array. And the TSP code will not work if it is not a
symmetric matrix with all values filled in. My note about checking the
matrix was a hint check for these issues. Symmetric means the 2-3 has to
be equal to 3-2 and the diagonal is all zeros.
-Steve
More information about the pgrouting-dev
