[pgrouting-dev] testing TSP example fails
Stephen Mather
stephen at smathermather.com
Sat Jun 15 13:39:10 PDT 2013
Ubuntu 12.04LTS
Postgis 2.0.1 r9979
GEOS 3.3.8-capi-1.7.8
proj 4.8.0
gdal 1.9.2
Libxml 2.7.8
pgr_version ()
2.0.0-Dev
V2.0.0-alpha,31,15ac46d,feature-travis,1.46.1
When I run tests, it fails on every test w function not found. Do I need to prep the database in any way to run the tests?
Stephen Mather <stephen at smathermather.com> wrote:
>I have not tried tests yet but have have run astar and djikstra w no problem. When does vacation start... I can run tests asap... :)
>Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>>On 6/15/2013 2:44 PM, Stephen Mather wrote:
>>> Hi All,
>>> More TSP for today. In testing the example in the docs against the
>>> example data, I get what is to me a cryptic error:
>>> SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
>>> vertex_table','2,7,11',7);
>>> ERROR: Error TSP fail to findEulerianPath, check your distance matrix
>>> is valid.
>>This typically means there is something bad happening in the distance
>>matrix that is getting passed to the TSP function. Hmmm.
>>I would start with can you run the test cases or do they fail on your
>>system.
>>What OS system and versions of stuff are you running?
>>There TSP solution for 3 points is a triangle, it is a trivial case
>>where the input is the output. I thought is tested for that case but
>>maybe not.
>>BTW, I will be away on vacation without net access through June 25th, so
>>I will not be much help until I get back.
>>-Steve
>>> ********** Error **********
>>> ERROR: Error TSP fail to findEulerianPath, check your distance matrix is
>>> valid.
>>> SQL state: XX000
>>> I get an entirely different error against my OSM data, but one error at
>>> a time... .
>>> Best,
>>> Steve
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
