[pgrouting-dev] testing TSP example fails
Stephen Mather
stephen at smathermather.com
Sat Jun 15 16:08:30 PDT 2013
Cool. Thanks Steve. Enjoy your vacation!
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>OK, those are benign for some reason postgres is not consistent about
>the way it issues NOTICE statements on different versions of so it those
>are false failures.
>If you want to file a ticket on the failure with enough info on how to
>reproduce it, I'll look at it when I get back.
>Thanks,
> -Steve
>On 6/15/2013 5:27 PM, Stephen Mather wrote:
>> Ok, definitely some failures:
>> $stats = {
>> 'src/apsp_johnson/test/test.conf' => [
>> 'comment' => 'APSP
>> Johnson test for any versions.',
>> 'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
>> 'src/apsp_warshall/test/test.conf' => [
>> 'comment' => 'APSP
>> Warshall test for any versions.',
>> 'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
>> 'src/astar/test/test.conf' => [
>> 'comment' => 'astar test
>> for any versions.',
>> 'src/astar/test/spas-any-00.test' => 'Passed',
>> 'src/astar/test/spas-any-01.test' => 'Passed'
>> 'src/bd_astar/test/test.conf' => [
>> 'comment' =>
>> 'Bi-directional AStar test for any versions.',
>> 'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
>> 'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
>> 'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
>> 'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
>> 'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
>> 'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
>> 'src/bd_dijkstra/test/test.conf' => [
>> 'comment' =>
>> 'Bi-directional Dijkstra test for any versions.',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
>> 'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
>> 'src/common/test/test.conf' => [
>> 'comment' =>
>> 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for
>> any versions.',
>> 'src/common/test/common-any-01.test' => 'FAILED: 1,3d0
>> < psql:src/common/test/common-any-01.test:1: NOTICE: table
>> "vertices_tmp" does not exist, skipping
>> < CONTEXT: SQL statement "DROP TABLE IF EXISTS vertices_tmp"
>> < PL/pgSQL function pgr_createtopology(character varying,double
>> precision,character varying,character varying) line 48 at SQL statement
>> 6c3
>> precision,character varying,character varying) line 49 at SQL statement
>> > PL/pgSQL function "pgr_createtopology" line 49 at SQL statement',
>> 'src/common/test/common-any-02.test' => 'Passed',
>> 'src/common/test/common-any-03.test' => 'Passed',
>> 'src/common/test/common-any-04.test' => 'FAILED: 3c3
>> < PL/pgSQL function pgr_nodenetwork(text,text,text,text,double
>> precision) line 23 at SQL statement
>> > PL/pgSQL function "pgr_nodenetwork" line 23 at SQL statement
>> 9c9
>> precision) line 58 at SQL statement
>> > PL/pgSQL function "pgr_nodenetwork" line 58 at SQL statement
>> 12c12
>> precision) line 71 at EXECUTE statement
>> > PL/pgSQL function "pgr_nodenetwork" line 71 at EXECUTE statement
>> 62c62
>> 'src/common/test/versionless-any-01.test' => 'Passed'
>> 'src/dijkstra/test/test.conf' => [
>> 'comment' => 'Dijkstra
>> 'src/dijkstra/test/spd-any-00.test' => 'Passed',
>> 'src/dijkstra/test/spd-any-01.test' => 'Passed',
>> 'src/dijkstra/test/spd-any-02.test' => 'Passed',
>> 'src/dijkstra/test/spd-any-03.test' => 'Passed'
>> 'src/driving_distance/test/test.conf' => [
>> 'comment' => 'Driving Distance test for any versions.',
>> 'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
>> 'src/kdijkstra/test/test.conf' => [
>> 'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
>> 'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed'
>> 'src/ksp/test/test.conf' => [
>> 'comment' => 'KSP test for
>> any versions.',
>> 'src/ksp/test/ksp-any-01.test' => 'Passed',
>> 'src/ksp/test/ksp-any-02.test' => 'Passed'
>> 'src/trsp/test/test.conf' => [
>> 'comment' => 'TRSP test for
>> any versions.',
>> 'src/trsp/test/trsp-any-00.test' => 'Passed',
>> 'src/trsp/test/trsp-any-01.test' => 'Passed',
>> 'src/trsp/test/trsp-any-02.test' => 'Passed',
>> 'src/trsp/test/trsp-any-03.test' => 'Passed'
>> 'src/tsp/test/test.conf' => [
>> 'comment' => 'TSP test for
>> any versions.',
>> 'src/tsp/test/tsp-any-00.test' => 'Passed',
>> 'src/tsp/test/tsp-any-01.test' => 'Passed',
>> 'src/tsp/test/tsp-any-02.test' => 'Passed'
>> 'z_crash' => 0,
>> 'z_fail' => 2,
>> 'z_pass' => 35
>> On 06/15/2013 05:09 PM, Stephen Mather wrote:
>>> Hmm. I did a clone w -b develop, so I never did a checkout of the
>>> repository after the clone. Also didn't configure the docs
>>> dependencies. Otherwise, it looks the same. About to rerun...
>>>> If you are in the pgrouting git source tree like:
>>>> git clone git://github.com/pgRouting/pgrouting.git
>>>> cd pgrouting
>>>> git checkout develop
>>>> cat tools/doit # this is my build script, it may not work for you
>>>> tools/doit
>>>> tools/test-runner.pl # this will run all the tests
>>>> The test script make a test database, loads the data and runs the tests.
>>>> If you look in src/tsp/test
>>>> CMakeLists.txt tsp-any-00.rest tsp-any-01.test tsp-any-03.rest
>>>> test.conf tsp-any-00.test tsp-any-02.rest tsp-any-03.test
>>>> tsp-any-00.data tsp-any-01.rest tsp-any-02.test
>>>> createdb runtests
>>>> psql runtests -c "create extension postgis"
>>>> psql runtests -c "create extension pgrouting"
>>>> psql runtests -f src/tsp/test/tsp-any-00.data # load some data
>>>> psql runtests -A -t -f src/tsp/test/tsp-any-00.test
>>>> psql runtests -A -t -f src/tsp/test/tsp-any-01.test
>>>> psql runtests -A -t -f src/tsp/test/tsp-any-02.test
>>>> psql runtests -A -t -f src/tsp/test/tsp-any-03.test
>>>> The output of each command should be the same as *.rest file.
>>>> -Steve
>>>> On 6/15/2013 4:39 PM, Stephen Mather wrote:
>>>>> Ubuntu 12.04LTS
>>>>> Postgis 2.0.1 r9979
>>>>> GEOS 3.3.8-capi-1.7.8
>>>>> proj 4.8.0
>>>>> gdal 1.9.2
>>>>> Libxml 2.7.8
>>>>> pgr_version ()
>>>>> 2.0.0-Dev
>>>>> V2.0.0-alpha,31,15ac46d,feature-travis,1.46.1
>>>>> When I run tests, it fails on every test w function not found. Do I
>>>>> need to prep the database in any way to run the tests?
>>>>> Stephen Mather <stephen at smathermather.com> wrote:
>>>>>> I have not tried tests yet but have have run astar and djikstra w
>>>>>> no problem. When does vacation start... I can run tests asap... :)
>>>>>>> On 6/15/2013 2:44 PM, Stephen Mather wrote:
>>>>>>>> Hi All,
>>>>>>>> More TSP for today. In testing the example in the docs against the
>>>>>>>> example data, I get what is to me a cryptic error:
>>>>>>>> SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
>>>>>>>> vertex_table','2,7,11',7);
>>>>>>>> ERROR: Error TSP fail to findEulerianPath, check your distance
>>>>>>>> matrix
>>>>>>>> is valid.
>>>>>>> This typically means there is something bad happening in the distance
>>>>>>> matrix that is getting passed to the TSP function. Hmmm.
>>>>>>> I would start with can you run the test cases or do they fail on your
>>>>>>> system.
>>>>>>> What OS system and versions of stuff are you running?
>>>>>>> There TSP solution for 3 points is a triangle, it is a trivial case
>>>>>>> where the input is the output. I thought is tested for that case but
>>>>>>> maybe not.
>>>>>>> BTW, I will be away on vacation without net access through June
>>>>>>> 25th, so
>>>>>>> I will not be much help until I get back.
>>>>>>> -Steve
>>>>>>>> ********** Error **********
>>>>>>>> matrix is
>>>>>>>> valid.
>>>>>>>> SQL state: XX000
>>>>>>>> I get an entirely different error against my OSM data, but one
>>>>>>>> error at
>>>>>>>> a time... .
>>>>>>>> Best,
>>>>>>>> Steve
>>>>>>>> _______________________________________________
>>>>>>>> pgrouting-dev mailing list
>>>>>>>> pgrouting-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
