[pgrouting-dev] TSP, server crashes and what nots
sanak geosanak at gmail.com
Thu Jun 27 00:27:11 PDT 2013
Hi Dave,
Sorry, I just started to check new pgRouting 2.0 and its issues,
but, if you use Linux(Ubuntu .etc), it seems that there is no reported
issue about ksp memory problems.
So, in that case, could you create a new issue?
Regards,
2013/6/27 Dave Potts <dave.potts at pinan.co.uk>
>  On 27/06/13 07:07, sanak wrote:
> hi
> Is there a bug tag with the memory problems ?
> I had some rather strange experiences with memory issues when I was
> writing the ksp wrapper.
> Another gotcha on the web site for getting the source version refer to 1.0
> release and not the development one.
> Dave.
> **<https://www.google.co.uk/search?client=ubuntu&hs=GgR&channel=cs&q=experiences&spell=1&sa=X&ei=KdnLUZqKMMjJOafZgcAK&ved=0CCwQvwUoAA>
> Hi Stephen,
>  Thanks for comment.
>  I will try to fix Windows/Mac related critical issues at next week.
>  Regards,
>  2013/6/27 Stephen Woodbridge <woodbri at swoodbridge.com>
>> Hi All,
>> Dave P. - thanks for the TSP problem reports.
>> Nagase-san - thank you for the crash reports.
>> My schedule is for the next 2 wks will be focused on some contract work I
>> have to deliver So I'm not sure how much time I will have to tackle
>> pgRouting issues.
>> I think I can work in looking at the new TSP issues for that starts. My
>> next major pgrouting task is to look at them memory issues that are causing
>> crashes and std::bad_alloc issues. I'm not looking forward to this task
>> because the problems seems to be intermitent and the fact that is works in
>> one setup does not mean that you have solved the problem. I also think this
>> is related to postgresql palloc usage and subtle issues related to that.
>> Thanks,
>>   -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>  Ko Nagase (sanak)
> Georepublic Japan
> mail: geosanak at gmail.com
>         nagase at georepublic.co.jp
> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Ko Nagase (sanak)
Georepublic Japan
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130627/ba988bf6/attachment.html>
More information about the pgrouting-dev mailing list
