[pgrouting-dev] library versions
Stephen Mather
stephen at smathermather.com
Thu Jun 27 19:35:09 PDT 2013
Perfect. Thank you. I've had trouble on Ubuntu, but none on Debian.
I'm hoping to get a moment to breath so I can document versions, etc..
On Ubuntu 12.04, everything compiles fine with the libraries I'm using
(except sphinx-- don't know why) but TSP and topology builds fail.
Hopefully in the next few weeks, things will let up enough for me to
document and ticket if necessary.
Best,
Steve
On 06/27/2013 10:27 PM, Daniel Kastl wrote:
> Hi Stephen,
> I wrote TBD, because I have to figure out first what would be the
> minimum required version.
> But trying to find this out is not so much fun ;-)
> There is currently only CMake that requires a rather new version.
> The rest doesn't seem to be a problem. So I'm not sure I want to spend
> much time in trying to compile with ancient library versions.
> We try to make pgRouting work with the recommended PostgreSQL versions
> of PostGIS, see the matrix:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> So far I had no version issues (except CMake) with dependencies and I
> have created packages for Ubuntu 12.04, 12.10 and 13.04
> This is the Debian control file to create the packages, which lists
> the required libraries:
> https://github.com/pgRouting/pgrouting-build/blob/master/debian/control
> Daniel
> On Fri, Jun 28, 2013 at 11:07 AM, Stephen Mather
> <stephen at smathermather.com <mailto:stephen at smathermather.com>> wrote:
> In the documentation for compilation, several of the library
> version are listed as TBD-- any guesses/recommendations (known
> versions that work) for those libraries? What does a typical (in
> Steve's case) debian build look like library-wise?
> Thanks,
> Best,
> Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130627/8198c5d1/attachment.html>
More information about the pgrouting-dev
