[pgrouting-dev] Documentation for 1.x
Daniel Kastl daniel at georepublic.de
Sun Jun 30 18:47:59 PDT 2013
Quick answer: "yes", it's one comma too much. ;)
Thanks!
Daniel
On Mon, Jul 1, 2013 at 4:34 AM, Stephen Mather <mather.stephen at gmail.com>wrote:
> Quick thing on the documentation for 1.x-- an extra comma in the Dijkstra
> (shortest_path) docs. after "AS cost"
> SELECT * FROM shortest_path('SELECT gid AS id, source::int4,             target::int4, length::double precision AS cost,        FROM dourol',3, 7, false, false);
> SELECT * FROM shortest_path('SELECT gid AS id, source::int4,             target::int4, length::double precision AS cost        FROM dourol',3, 7, false, false);
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130701/2f57a43b/attachment.html>
More information about the pgrouting-dev mailing list
