[pgrouting-dev] Integer types
Daniel Kastl
daniel at georepublic.de
Sun Jun 30 18:58:59 PDT 2013
On Mon, Jul 1, 2013 at 10:45 AM, Stephen Mather
<stephen at smathermather.com>wrote:
> In general using OSM data is working great in pgRouting. One place which
> still needs to be patched with allowing big integers is alphashape and
> points as polygon.
Hi Steve,
You're right that big integers are not supported and I just had to revert a
change in osm2pgrouting, because I had tried to change "gid" to bigint,
which caused wrong topology and routes. I think such a change would be a
more difficult task, because pgRouting makes use of shortest path
implementation of Boost library.
Nevertheless I believe that it's not really urgent issue and problem that
pgRouting does not support bigint right now. OSM just needs these 32bit
ID's, because in their database every way and node gets an ID. For
pgRouting we just use a subset of this data (roads), so I would doubt that
there is right now road network data of a size, that really requires bigint
type.
Of course it'S necessary that import tools like osm2pgrouting are able to
handle 32bit ID's when they parse OSM data, and they may store "osm_id" as
an attribute for reference to the original OSM object. But there is no need
to use the same ID's for "gid", "source" and "target" attributes. It would
be even bad for performance not to renumber the ID's to have smaller
numbers.
Or did I misunderstand something?
Daniel
> Best,
> Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130701/76e49d13/attachment.html>
More information about the pgrouting-dev
