[pgrouting-dev] Integer types
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jun 30 19:41:09 PDT 2013
On 6/30/2013 10:37 PM, Daniel Kastl wrote:
> Daniel - if this is not happening in osm2pgrouting now it probably
> should get implemented this way.
> It's already fixed. There was a pull request, which changed various ID's
> to bigint and I reverted "gid" to integer. Other ID's seem to be OK.
Ok, cool. My brain is only partially engaged in pgrouting at the moment.
I just did a dist-upgrade from squeeze to wheezy and I need to recompile
a lot of extra stuff and the autotools stuff seems to be broken in the
new versions or incompatible with my old project config files. It would
nice if the world upgraded to cmake ;)
-Steve
More information about the pgrouting-dev
