[pgrouting-dev] Quick 2.0 Update
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 6 20:57:51 PST 2013
Hi All,
Today, I got cmake changes made so it now builds and compiles using the
new tree structure. This required upgrading to cmake 2.8. I have not
tried to install it in postgresql yet. These changes have been pushed to
github.
I also have been looking at cmake to figure out how to intall all then
build pieces as a postgresql extension and think I have most of that
figured out.
More to follow as it gets done,
   -Steve
On 3/5/2013 4:39 PM, Stephen Woodbridge wrote:
> Hi All,
> Just a quick update.
> * new branch sew-devel-2_0
> * moved files into a new tree structure
> * merged trsp into this structure
> * checkin and pushed
> * started working on getting just this much to build
> * making changes to cmake stuff and debugging locally
> * will push these changes soon
> I also make some minor comments on the 2.0 dev wiki page. I'll update
> this once things settle down a little:
> https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan
> I found one thing I don't like about this structure and that is there
> are more little sql files to deal with, but my hope is that these can
> all be hidden as part of the CREATE EXTENSION command when I get to that.
> My plan is something like this:
> * get current tree to compile on old debian with pg8.3 and postgis 1.5.x
> * I need to find/setup a system with pg9.1+ and postgis 2.0.x
> * get it to compile there
> * get the extension packaging to work
> * get it working with windows
> * then start renaming procedures and clean all that up (this might need
> to be done sooner rather than later).
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
