[pgrouting-dev] Problems linking on mingw64 between boost, cgal and threads
Pieter du Plooy
pjduplooy at zpanelcp.com
Tue Mar 12 10:27:01 PDT 2013
@Sanak
Pleasure
On Tue, Mar 12, 2013 at 5:34 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Sanak,
> I'm still have an issue with this. Hopefully I followed your changes
> correctly:
> In my msys.bat shell I added the to the path: /c/ming64/mingw64/bin/, I
> have /c/ming64/ and /c/ming32/ trees setup so I can build on either.
> start cmd
> gcc -v # is found and run
> bootstrap.bat gcc # fails
> bootstrap.bat mingw # fails
> exit
> $ cat tools/build/bjam.log
> ### Using 'msvc' toolset.
> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>if exist
> bootstrap rd /S /Q bootstrap
> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>md bootstrap
> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>cl /nologo
> /GZ /Zi /MLd /Fobootstrap/ /Fdbootstrap/ -DNT -DYYDEBUG kernel32.lib
> advapi32.lib user32.lib /Febootstrap\jam0 command.c compile.c debug.c
> execnt.c expand.c filent.c glob.c hash.c hdrmacro.c headers.c jam.c
> jambase.c jamgram.c lists.c make.c make1.c newstr.c option.c output.c
> parse.c pathunix.c regexp.c rules.c scan.c search.c subst.c timestamp.c
> variable.c modules.c strings.c filesys.c builtins.c md5.c pwd.c class.c
> w32_getreg.c native.c modules/set.c modules/path.c modules/regex.c
> modules/property-set.c modules/sequence.c modules/order.c
> I looked at tools/build/v2/engine/src/**build.bat but I'm not very
> familiar with windows bat files.
> -Steve
> On 3/12/2013 9:15 AM, sanak wrote:
>> Hi Stephen,
>> I updated MinGW32/64 build instruction to my "mingw" branch,
>> and checked that MinGW64-bit build successed. (but not tested)
>> https://github.com/sanak/**pgrouting4w/commit/**
>> 2a660524b53bcd80005e52917af5b3**2b31749559<https://github.com/sanak/pgrouting4w/commit/2a660524b53bcd80005e52917af5b32b31749559>
>> so, retry from boost build about ISSUE1. (Thanks Pieter!)
>> Regards,
>> 2013/3/12 Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>
>> Hi all,
>> I'm stuck at the moment trying to link the pgrouting driving
>> directions module using mingw 64 bit. See the issues below. So if
>> anyone has any thoughts on this it would be appreciated. I will
>> check the current state of the files into my branch in the morning
>> here (GMT-5) if you are setup to reproduce this. It is too late to
>> do it with a clear head tonight. I'll also move it back to Linux and
>> try again there as I have changed a lot of files.
>> Thanks,
>> -Steve
>> I have followed Sanak's directions from:
>> https://github.com/sanak/__**pgrouting4w/blob/master/BUILD.**
>> __mingw64<https://github.com/sanak/__pgrouting4w/blob/master/BUILD.__mingw64>
>> <https://github.com/sanak/**pgrouting4w/blob/master/BUILD.**mingw64<https://github.com/sanak/pgrouting4w/blob/master/BUILD.mingw64>
>> ISSUE 1:
>> I first installed boost_1_51.zip but ran into problems compiling so
>> installed boost_1_46_1.zip as he suggested. I was able to bootstrap
>> 1_51 and get a bjam.exe without a problem. But I could not get
>> 1_46_1 to bootstrap :(
>> Microsoft Windows [Version 6.1.7601]
>> Copyright (c) 2009 Microsoft Corporation. All rights reserved.
>> c:\ming64\projects\boost_1_46_**__1>bootstrap.bat mingw
>> Building Boost.Jam build engine
>> 'cl' is not recognized as an internal or external command,
>> operable program or batch file.
>> Failed to build Boost.Jam build engine.
>> Please consult bjam.log for furter diagnostics.
>> You can try to obtain a prebuilt binary from
>> http://sf.net/project/__**showfiles.php?group_id=7586&__**
>> package_id=72941<http://sf.net/project/__showfiles.php?group_id=7586&__package_id=72941>
>> <http://sf.net/project/**showfiles.php?group_id=7586&**
>> package_id=72941<http://sf.net/project/showfiles.php?group_id=7586&package_id=72941>
>> Also, you can file an issue at http://svn.boost.org
>> Please attach bjam.log in that case.
>> So I built 1_46_1 using the bjam.exe that I built in 1_51 and it
>> seems to have worked ok, but maybe that is part of the problem.
>> ISSUE 2:
>> Is the follow mess from the linker
>> Scanning dependencies of target routing_dd
>> [ 80%] Building C object
>> core/driving_distance/src/__**CMakeFiles/routing_dd.dir/__**
>> alpha.c.obj
>> [ 86%] Building CXX object
>> alpha_drivedist.cpp.obj
>> In file included from
>> c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/**
>> pg___config_os.h:37:0,
>> from
>> c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/c.**
>> h:__87,
>> from
>> c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/__**
>> postgres.h:47,
>> from
>> c:/ming64/projects/pgrouting/_**_core/driving_distance/src/__**
>> alpha.h:27,
>> from
>> alpha_drivedist.cpp:46:
>> c:\ming64\mingw64\bin\../lib/_**_gcc/x86_64-w64-mingw32/4.5.4/**
>> .__./../../../x86_64-w64-**mingw32/__include/winsock2.h:**13:2:
>> warning: #warning Please include winsock2.h before windows.h
>> [ 93%] Building CXX object
>> boost_drivedist.cpp.obj
>> [100%] Building C object
>> drivedist.c.obj
>> Linking CXX shared library ../../../lib/librouting_dd.dll
>> Creating library file: ../../../lib/librouting_dd.__**dll.a
>> c:/ming64/msys/local/lib/__**libboost_thread-mgw45-mt-1_46_**
>> __1.a(thread.o):
>> duplicate section
>> `.data$_ZTVN5boost16exception_**__detail10clone_implINS0___**
>> 19error_info_injectorISt9bad__**_allocEEEE[vtable
>> for
>> boost::exception_detail::__**clone_impl<boost::exception___**
>> detail::error_info_injector<__**std::bad_alloc>
>> >]' has different size
>> c:/ming64/msys/local/lib/__**libCGAL.a(all_files.cpp.obj):_**
>> _all_files.cpp:(.text+0xf898):
>> undefined reference to `boost::system::generic___**category()'
>> _all_files.cpp:(.text+0xf8a4):
>> _all_files.cpp:(.text+0xf8b0):
>> undefined reference to `boost::system::system___**category()'
>> collect2: ld returned 1 exit status
>> make[2]: *** [lib/librouting_dd.dll] Error 1
>> make[1]: ***
>> [core/driving_distance/src/__**CMakeFiles/routing_dd.dir/all] Error 2
>> make: *** [all] Error 2
>> ______________________________**___________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130312/d772700c/attachment-0001.html>
More information about the pgrouting-dev
