[pgrouting-dev] Problems linking on mingw64 between boost, cgal and threads
sanak geosanak at gmail.com
Tue Mar 12 15:01:04 PDT 2013
Hi Stephen,
Oops, sorry, my boost_1_46_1/tools/build/bjam.log shows "msvc10" which I
have installed...
I will check after returning from work. (about 12 hour later)
Regards,
2013/3/13 Stephen Woodbridge <woodbri at swoodbridge.com>
> OK, it looks like I have solved ISSUE 2, I think this was caused because I
> built boost with the 32 bit model in the 64 bit environment. I still can
> not not get ISSUE 1 to resolve and I had to rebuild it using the bjam I
> built under 1_51.
> To fix ISSUE to:
> 1. rebuilt boost_1_46_1 as 64 bit model using bjam from 1_51
> 2. rebuild CGAL
> 3. rebuild pgrouting
> So I have at least on cuild of pgRouting
> So making progress in small steps :)
> If you have any additional thoughts on getting boost to build they would
> be appreciated.
> In my msys.bat shell, I have:
> PATH=/c/ming64/mingw64/bin/:/**home/woodbri/bin:.:/usr/local/**
> bin:/mingw/bin:/bin:/c/oracle/**product/10.2.0/db_1/bin:/c/**
> Windows/system32:/c/Windows:/**c/Windows/System32/Wbem:/c/**
> Windows/System32/**WindowsPowerShell/v1.0/:/c/**Program Files
> (x86)/QuickTime/QTSystem/
> Thanks,
>   -Steve
> On 3/12/2013 11:34 AM, Stephen Woodbridge wrote:
>> Hi Sanak,
>> I'm still have an issue with this. Hopefully I followed your changes
>> correctly:
>> In my msys.bat shell I added the to the path: /c/ming64/mingw64/bin/, I
>> have /c/ming64/ and /c/ming32/ trees setup so I can build on either.
>> start cmd
>> gcc -v               # is found and run
>> bootstrap.bat gcc    # fails
>> bootstrap.bat mingw  # fails
>> exit
>> $ cat tools/build/bjam.log
>> ### Using 'msvc' toolset.
>> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>if exist
>> bootstrap rd /S /Q bootstrap
>> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>md bootstrap
>> c:\ming64\projects\boost_1_46_**1\tools\build\v2\engine\src>cl /nologo
>> /GZ
>> /Zi /MLd /Fobootstrap/ /Fdbootstrap/ -DNT -DYYDEBUG kernel32.lib
>> advapi32.lib user32.lib /Febootstrap\jam0  command.c compile.c debug.c
>> execnt.c expand.c filent.c glob.c hash.c hdrmacro.c headers.c jam.c
>> jambase.c jamgram.c lists.c make.c make1.c newstr.c option.c output.c
>> parse.c pathunix.c regexp.c rules.c scan.c search.c subst.c timestamp.c
>> variable.c modules.c strings.c filesys.c builtins.c md5.c pwd.c class.c
>> w32_getreg.c native.c modules/set.c modules/path.c modules/regex.c
>> modules/property-set.c modules/sequence.c modules/order.c
>> I looked at tools/build/v2/engine/src/**build.bat but I'm not very
>> familiar with windows bat files.
>> -Steve
>> On 3/12/2013 9:15 AM, sanak wrote:
>>> Hi Stephen,
>>> I updated MinGW32/64 build instruction to my "mingw" branch,
>>> and checked that MinGW64-bit build successed. (but not tested)
>>> https://github.com/sanak/**pgrouting4w/commit/**
>>> 2a660524b53bcd80005e52917af5b3**2b31749559<https://github.com/sanak/pgrouting4w/commit/2a660524b53bcd80005e52917af5b32b31749559>
>>> so, retry from boost build about ISSUE1. (Thanks Pieter!)
>>> Regards,
>>> 2013/3/12 Stephen Woodbridge <woodbri at swoodbridge.com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>
>>>     Hi all,
>>>     I'm stuck at the moment trying to link the pgrouting driving
>>>     directions module using mingw 64 bit. See the issues below. So if
>>>     anyone has any thoughts on this it would be appreciated. I will
>>>     check the current state of the files into my branch in the morning
>>>     here (GMT-5) if you are setup to reproduce this. It is too late to
>>>     do it with a clear head tonight. I'll also move it back to Linux and
>>>     try again there as I have changed a lot of files.
>>>     Thanks,
>>>        -Steve
>>>     I have followed Sanak's directions from:
>>>     https://github.com/sanak/__**pgrouting4w/blob/master/BUILD.**
>>> __mingw64<https://github.com/sanak/__pgrouting4w/blob/master/BUILD.__mingw64>
>>>     <https://github.com/sanak/**pgrouting4w/blob/master/BUILD.**mingw64<https://github.com/sanak/pgrouting4w/blob/master/BUILD.mingw64>
>>>     ISSUE 1:
>>>     I first installed boost_1_51.zip but ran into problems compiling so
>>>     installed boost_1_46_1.zip as he suggested. I was able to bootstrap
>>>     1_51 and get a bjam.exe without a problem. But I could not get
>>>     1_46_1 to bootstrap :(
>>>     Microsoft Windows [Version 6.1.7601]
>>>     Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
>>>     c:\ming64\projects\boost_1_46_**__1>bootstrap.bat mingw
>>>     Building Boost.Jam build engine
>>>     'cl' is not recognized as an internal or external command,
>>>     operable program or batch file.
>>>     Failed to build Boost.Jam build engine.
>>>     Please consult bjam.log for furter diagnostics.
>>>     You can try to obtain a prebuilt binary from
>>> http://sf.net/project/__**showfiles.php?group_id=7586&__**
>>> package_id=72941<http://sf.net/project/__showfiles.php?group_id=7586&__package_id=72941>
>>>     <http://sf.net/project/**showfiles.php?group_id=7586&**
>>> package_id=72941<http://sf.net/project/showfiles.php?group_id=7586&package_id=72941>
>>>     Also, you can file an issue at http://svn.boost.org
>>>     Please attach bjam.log in that case.
>>>     So I built 1_46_1 using the bjam.exe that I built in 1_51 and it
>>>     seems to have worked ok, but maybe that is part of the problem.
>>>     ISSUE 2:
>>>     Is the follow mess from the linker
>>>     Scanning dependencies of target routing_dd
>>>     [ 80%] Building C object
>>>     core/driving_distance/src/__**CMakeFiles/routing_dd.dir/__**
>>> alpha.c.obj
>>>     [ 86%] Building CXX object
>>> alpha_drivedist.cpp.obj
>>>     In file included from
>>> c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/**
>>> pg___config_os.h:37:0,
>>>                       from
>>>     c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/c.**
>>> h:__87,
>>>                       from
>>> c:/ming64/projects/pgx64/pg92/**__include/postgresql/server/__**
>>> postgres.h:47,
>>>                       from
>>> c:/ming64/projects/pgrouting/_**_core/driving_distance/src/__**
>>> alpha.h:27,
>>>                       from
>>> alpha_drivedist.cpp:46:
>>> c:\ming64\mingw64\bin\../lib/_**_gcc/x86_64-w64-mingw32/4.5.4/**
>>> .__./../../../x86_64-w64-**mingw32/__include/winsock2.h:**13:2:
>>>     warning: #warning Please include winsock2.h before windows.h
>>>     [ 93%] Building CXX object
>>> boost_drivedist.cpp.obj
>>>     [100%] Building C object
>>> drivedist.c.obj
>>>     Linking CXX shared library ../../../lib/librouting_dd.dll
>>>     Creating library file: ../../../lib/librouting_dd.__**dll.a
>>> c:/ming64/msys/local/lib/__**libboost_thread-mgw45-mt-1_46_**
>>> __1.a(thread.o):
>>>     duplicate section
>>> `.data$_ZTVN5boost16exception_**__detail10clone_implINS0___**
>>> 19error_info_injectorISt9bad__**_allocEEEE[vtable
>>>     for
>>> boost::exception_detail::__**clone_impl<boost::exception___**
>>> detail::error_info_injector<__**std::bad_alloc>
>>>      >]' has different size
>>> c:/ming64/msys/local/lib/__**libCGAL.a(all_files.cpp.obj):_**
>>> _all_files.cpp:(.text+0xf898):
>>>     undefined reference to  `boost::system::generic___**category()'
>>> _all_files.cpp:(.text+0xf8a4):
>>> _all_files.cpp:(.text+0xf8b0):
>>>     undefined reference to `boost::system::system___**category()'
>>>     collect2: ld returned 1 exit status
>>>     make[2]: *** [lib/librouting_dd.dll] Error 1
>>>     make[1]: ***
>>>     [core/driving_distance/src/__**CMakeFiles/routing_dd.dir/all] Error
>>> 2
>>>     make: *** [all] Error 2
>>>     ______________________________**___________________
>>>     pgrouting-dev mailing list
>>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>>     http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>>     <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130313/f471b6d0/attachment.html>
More information about the pgrouting-dev mailing list
