[pgrouting-dev] pgRouting 2.0 Update
Sandro Santilli
strk at keybit.net
Wed Mar 13 00:14:57 PDT 2013
Hi Stephen,
is the branch supposed to be buildable on linux ?
I've been trying w/out success two days ago, while I filed a couple
of pull requests to be able to build the "master" branch on Ubuntu 12.04
(hint: waiting for merge :)
Should I file tickets for build errors in the 2.0 branch ?
Which branch name, exactly ?
Thanks in advance
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
On Tue, Mar 12, 2013 at 11:13:05PM -0400, Stephen Woodbridge wrote:
> Hi all,
> I'm making some progress with pgRouting on Win64. I have been able
> to get my source tree to compile which means I have worked through
> the various issues of installing the various dependencies to
> pgRouting. There are still a few minor issues in this regard and
> Sanak is looking into one related to installing boost.
> My source tree is not complete yet from the point of view that it
> still needs changes for:
> 1. creating all the postgresql extension files and installing them properly
> 2. for up grading the SQL to work with postgis 2.0+
> 3. testing the installed code
> 4. getting everything to work with 32 bit builds
> But getting the dependencies to install and getting the source to
> compile on MinGW64 is a huge step. I have also brought the source
> back to Linux and made a few changes there. So a lot of back and
> forth to keep everything working on both sides.
> Thanks,
> -Steve
More information about the pgrouting-dev
