[pgrouting-dev] Can we use the "build" directory to build?
Daniel Kastl daniel at georepublic.de
Fri Mar 22 22:31:06 PDT 2013
> There are two small things I don't like:
>    1. Couldn't this somehow be part of the cmake configuration, so it
>    uses a build directory even cmake is run in project root ("cmake ../."
>    looks a bit weird, too) ... will try to find if this is possible.
> Well, already found it:
http://stackoverflow.com/questions/11143062/getting-cmake-to-build-out-of-source-without-wrapping-scripts
cmake -H. -Bbuild .
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130323/1dc48b1e/attachment-0001.html>
More information about the pgrouting-dev mailing list
