[pgrouting-dev] PostGIS 2.1, Postgresql 9.3 and pgRouting - We need a plan!
Paragon Corporation lr at pcorp.us
Sat May 4 08:32:50 PDT 2013
For the record I know your 1.07 branch builds (and for the tests I've done
works fine with PostGIS 9.2 (both 32-bit and 64-bit) and 2.1 except for the
bug I mentioned to Steve already with a driving distance call which is a
pgRouting bug not a windows one), but haven't tested against 9.3.
I haven't had a chance to test the pgrouting 2.0 branch yet.
I do have winnie pulling both 2.0 and 1.0 pgrouting branches, but have to
strap up to compile and test against both 9.2 and 9.3.  Hoping to do that
this weekend or next week.
Thanks,
Regina
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Friday, May 03, 2013 10:17 PM
To: pgrouting-dev at lists.osgeo.org; Paragon Corporation
Subject: Re: [pgrouting-dev] PostGIS 2.1, Postgresql 9.3 and pgRouting - We
need a plan!
On 5/3/2013 10:00 PM, Daniel Kastl wrote:
> On Sat, May 4, 2013 at 10:25 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Daniel, et al,
>     PostGIS 2.1 is hitting feature freeze to sync up with
>     PostgreSQL 9.3 which is going to Beta
>     And we need to be able to support PostGIS being able to package a
>     pgRouting on Windows with PostGIS 2.1. I already have pgrouting
>     build in the postgis build bot, so the focus should be on the code
>     and sql fixes as I outline below.
>     So I think we need a plan for this, and some people effort would be
>     good also.
>     It seems to me that we need someone to:
>     Setup an environment with pg 9.3 beta, postgis 2.1 trunk and take
>     our pgrouting master and make changes required to make it work in
>     that environment and package up a release.
>     This should not include any new features.
>     It should include ST_ fixes that we have a pull request for
>     It should include some of the bug fixes that we have pull requests for
>     It must include any additional compatibility changes.
>     It must include some basic testing (we can pull the tests from my
>     2.0 branch to make things simple)
>     This would be called version 1.06
>     This needs to happen after we move the branches around, which I hope
>     to get to on Sunday.
>     Anyone available to manage this release and tackle the items above?
>     Anyone able to fund this at any level?
>     Thoughts?
>     -Steve
>     _________________________________________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
> Hi Steve,
> "PostGIS 2.1, Postgresql 9.3 and pgRouting" ... this is particularly
> for Windows builds, isn't it?
> Unfortunately on Windows I have close to zero experience.
> I don't know how much time would be still available, but wouldn't it
> be possible (and less work) to use the new 2.0 version instead of
> trying another 1.06 release?
> Pulling changes from here and there might cause new issues and then we
> had to work on two releases at the same time. Otherwise we could just
> focus on one.
Daniel,
I think the problem is much easier than that. We need to do be able to
support this release on Linux also. For that matter we need to support 9.1,
9.2 and postGIS 2.0 which we don't today resulting in every user asking the
list how to get it to work.
So, we build and test on linux.
Regina can pull our source into the build bot.
I can build on Windows here (if I have to).
and we just plan to cut 1.06 release on Linux that fixes some bugs and
compatibility issues.
If we plan it like this then its more about the bugs, and compatibility and
yes at some point it gets tested on windows and if there are windows
specific issues, Regina and I can sort them out and check changes back into
the branch.
CC: Regina since she needs to interact with our efforts.
-Steve
More information about the pgrouting-dev mailing list
