[pgrouting-dev] pgRouting 2.0 using OSX homebrew
sanak geosanak at gmail.com
Wed May 8 16:39:59 PDT 2013
Hi Stephen,
2013/5/9 Stephen Woodbridge <woodbri at swoodbridge.com>
> I looked at your changes below, and they do not seem to be based on my
> branch "sew-devel-2_0". The quick tell is that my source starts at "src/"
> and not "core/" as your changes reflect.
Oh, sorry.
Thanks for notice.
For linux I compile, install and test using:
> tools/doit
> (cd build; sudo make install)
> tools/testrunner.pl
> In the C/C++ code you should be able to use:
> #ifdef __APPLE__
> #else
> #endif
> and in cmake you can use:
> if(APPLE)
> else(APPLE)
> endif(APPLE)
> Can you also post what the results of:
> echo | g++ -dM -E -
> when run on OSX.
> No hurray, when you can get to it, this weekend is fine.
Okay, thanks for detail.
Regards,
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130509/0172b34e/attachment.html>
More information about the pgrouting-dev mailing list
