[pgrouting-dev] pgRouting 2.0 using OSX homebrew
sanak geosanak at gmail.com
Wed May 8 16:49:03 PDT 2013
Hi Alec,
Thanks for your pull request!
2013/5/9 Alec Gosse <alec at thegosses.com>
> Thank you all for your guidance. I've submitted a pull request for my
> changes. As I noted in the text of the request, librouting_tsp and
> librouting_ksp are being built as static rather than dynamic libraries, so
> make install fails since they have the extension .a rather than .so. Any
> thoughts on this would be most appreciated.
> The only other trouble I've run across is a very long list of warnings
> like this while compiling:
> /usr/local/src/pgrouting/src/driving_distance/src/drivedist.c:220:34:
> warning: use of GNU old-style field designator extension [-Wgnu-designator]
>   edge_columns_t edge_columns = {id: -1, source: -1, target: -1,
I guess that above warning cause is Clang(LLVM)'s g++ compatibility,
so, more custom CMake settings may be necessary.
I will check about it in this weekend (or later).
Thanks,
Sanak
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130509/dd71b445/attachment.html>
More information about the pgrouting-dev mailing list
