[pgrouting-dev] 2.0 branch CGAL dependency and GEOS 3.4dev
Stephen Mather
mather.stephen at gmail.com
Fri May 10 08:04:12 PDT 2013
That makes sense. It's funny, cause I am currently pulling my hair out
with the opposite issue-- the cmake minimum not matching what's available
on Ubuntu 12.04, so yes-- no extra headaches in the form of dependency h*ll
should ever be lightly foisted upon the unaware... :).
Best,
Steve
On Fri, May 10, 2013 at 10:13 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/10/2013 9:53 AM, Stephen Mather wrote:
>> Apologies for the last e-mail with vague subject line. Another thought
>> on pgRouting dependencies-- any plans for cgal to be dropped once GEOS
>> 3.4 is readily available? It seems like it could be with Delaunay being
>> on GEO 3.4dev, but I don't know when the line gets moved for minimum
>> GEOS version (obviously sometime after it's no longer a dev version).
> Yes, that is the ultimate plan. We have a little chicken vs egg issue in
> that we need the new postgis functions so we can rewrite our code as you
> point out. We also have to be careful to not set the required postgis
> version too high too soon, because that will be a problem for the packagers
> where new releases lag behind.
> We have another options:
> 1. I have code that I could contribute as an interim solution, but that
> seems like a lot of work.
> 2. we could provide both a CGAL (depreciated) and a postgis SQL only
> solution that would only work if you have GEOS 3.4 install.
> So we will see how this evolves, given other work, release deadlines, pull
> requests, funding, etc.
> Thanks,
> -Steve W
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130510/c44b2b9c/attachment-0001.html>
More information about the pgrouting-dev
