[pgrouting-dev] 2.0 branch CGAL dependency and GEOS 3.4dev
Stephen Mather
mather.stephen at gmail.com
Fri May 10 08:58:04 PDT 2013
Cool. Tried jerry-rigging it first with changing the dependency
declaration, but that's a real dependency it seems.
Ya, cmake isn't too bad to build, so done.
Best,
Steve
On Fri, May 10, 2013 at 11:24 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/10/2013 11:04 AM, Stephen Mather wrote:
>> That makes sense. It's funny, cause I am currently pulling my hair out
>> with the opposite issue-- the cmake minimum not matching what's
>> available on Ubuntu 12.04, so yes-- no extra headaches in the form of
>> dependency h*ll should ever be lightly foisted upon the unaware... :).
> I just download the cmake source cmake-2.8.10.2.tar.gz and built that on
> debian. I know that is not desirable. Looks like you can get it from a PPA
> here:
> http://www.ubuntuupdates.org/**package/kubuntu-ppa_backports/**
> precise/main/base/cmake<http://www.ubuntuupdates.org/package/kubuntu-ppa_backports/precise/main/base/cmake>
> -Steve
> Best,
>> Steve
>> On Fri, May 10, 2013 at 10:13 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>> On 5/10/2013 9:53 AM, Stephen Mather wrote:
>> Apologies for the last e-mail with vague subject line. Another
>> thought
>> on pgRouting dependencies-- any plans for cgal to be dropped
>> once GEOS
>> 3.4 is readily available? It seems like it could be with
>> Delaunay being
>> on GEO 3.4dev, but I don't know when the line gets moved for
>> minimum
>> GEOS version (obviously sometime after it's no longer a dev
>> version).
>> Yes, that is the ultimate plan. We have a little chicken vs egg
>> issue in that we need the new postgis functions so we can rewrite
>> our code as you point out. We also have to be careful to not set the
>> required postgis version too high too soon, because that will be a
>> problem for the packagers where new releases lag behind.
>> We have another options:
>> 1. I have code that I could contribute as an interim solution, but
>> that seems like a lot of work.
>> 2. we could provide both a CGAL (depreciated) and a postgis SQL only
>> solution that would only work if you have GEOS 3.4 install.
>> So we will see how this evolves, given other work, release
>> deadlines, pull requests, funding, etc.
>> Thanks,
>> -Steve W
>> ______________________________**___________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130510/cd9e1a5b/attachment.html>
More information about the pgrouting-dev
