[pgrouting-dev] git dependency in (at least) pgRouting 2.0
Stephen Mather
mather.stephen at gmail.com
Fri May 10 19:22:00 PDT 2013
Cool. Thanks Daniel. I figure I'm the first person to try to install it
without git... :). It was a fresh install though.
Best,
Steve
On Fri, May 10, 2013 at 9:47 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> On Sat, May 11, 2013 at 12:59 AM, Stephen Mather <mather.stephen at gmail.com
> > wrote:
>> Here's a dependency not listed-- git itself is a dependency... . I know
>> this is a silly thing to point out, but it is possible on github to
>> download a zip of the file without installing git. Should git be added as
>> a dependency?
> I added a Cmake module to get some Git parameters, if available.
> It should check if it's not a Git repository, though I didn't think about
> it could fail if Git is not installed at all.
> Thanks for the comment, because I didn't think about it at all.
> I thought the Git module would be smart enough, but of course this
> shouldn't become a build dependency.
> Will take a look.
> Daniel
>> Best,
>> Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130510/e044b88f/attachment.html>
More information about the pgrouting-dev
