[pgrouting-dev] How many people use the wrapper functions?
Worth Lutz wal3 at mindspring.com
Sun May 12 04:52:47 PDT 2013
Steve,
Thanks for the suggestion on TSRP. I'll look at it as soon as I finish my
current project.
I'll like to add that I learned to write PL/pgSQl from reading the pgRouting
wrappers. I usually write in PHP but find that moving stuff to SQL and
PL/pgSQl can simplify my application. At least once I figure out the
intricacies of the particular query.
Having the wrapper examples is helpful to someone learning. I found that you
have to figure out how they work though because as you pointed out there
were problems and hard-coded stuff which may cause problems.  I had a type
problem when I was figuring out my application.
Simple wrappers as examples to explain to someone how to set up their own
wrapper are helpful.
Worth
-----Original Message-----
[mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Saturday, May 11, 2013 10:00 PM
To: pgRouting developers mailing list
Subject: Re: [pgrouting-dev] How many people use the wrapper functions?
Hi Worth,
Thank you for the feedback. It is really important the people speak up
on this because our current thinking is that we will probably take most
of the wrapper functions and dump them into a depreciated
pgrouting-legacy.sql file that will get copied to the server, but not
installed when you CREATE EXTENSION pgrouting;
I have talked with Daniel about improving the documentation and may be
adding a chapter that explains how to write your own wrapper function.
Our thought is that if we had fewer functions that were better
documented that it would be easier for people to make sense of how to
use from the beginning.
Regarding shooting star, you should just start using TRSP. In fact it
has the ability to specify an edge and a percentage along the edge for
the start and end locations. It also about 5 times faster than shooting
start.
With regards to the parallel edge problem. We have this in dijkstra and
astar and it is on my list of things to fix before the release. I am not
sure if trsp has this or not, but if you can make a test for it I would
be interested in the results.
Thanks,
   -Steve
On 5/11/2013 7:51 PM, Worth Lutz wrote:
> Hi Steve,
> I used one of the wrappers, shootingstar_sp_smart I think, but had to
modify
> it due to problems. I think that it is the one which uses shooting star
> which I've since heard doesn't work.
> I think that it works for us as all we are using is length as cost to find
> the length from a to b. No turn restrictions or anything.
> I chose it because the wrapper let me choose a point and it split the
> nearest edge and hooked up the point to that edge at the split.
> Another reason I chose it was that it worked for the following situation:
> A -----/               B
> |_____________________/
> Other algorithms would choose the upper edge because that is what was
found
> first as they tried to go from A to B. I was just learning about routing
and
> did not want to go figure out how to modify my network to split the long
> path where there were multiple paths between nodes.
> I've been following your work lately as I will be upgrading our situation
to
> Postgres 9 and PostGIS 2 at some point. I was waiting for you to get
things
> settled out before asking which algorithm I should look at to replace
> shootingstar.
> Thanks for your work on this project.
> Worth Lutz
> From: pgrouting-dev-bounces at lists.osgeo.org
> Woodbridge
> Sent: Saturday, May 11, 2013 4:21 PM
> To: pgRouting Users List; pgRouting Dev List
> Subject: [pgrouting-dev] How many people use the wrapper functions?
> Hi all,
> Daniel and I have been wondering if people use the wrapper function
> versus the core functions directly? Or if you have written your own
> wrapper functions? etc.
> The core functions are the low level function that directly call the
> internal library functions.
> The wrapper functions are all the additional plpgsql convenience
> functions that generate more complex SQL queries and then call the core
> functions.
> I know that I never use the wrapper functions because I found them to
> messy and inconsistent and have hard coded values in them, etc. So I
> wrote my own high level wrapper functions that made it easy for me to
> work with the core functions.
> So I thought it would be wise to ask our users what they use? and how
> they use pgRouting, so we do not may a decision like "Throw out the
> wrapper functions" without some input from the user community.
> PLEASE TAKE ACTION and let us know!
> Thanks,
>     -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.3336 / Virus Database: 3162/6317 - Release Date: 05/11/13
More information about the pgrouting-dev mailing list
