[pgrouting-dev] Bidirectional Integration bug
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 16 12:31:46 PDT 2013
Hi Razequl,
I did a little more research on this problem and added try-catch block
in your C++ wrapper function which is reporting: std::bad_alloc
In general, I think for robustness we need all C++ code to include try
blocks and clean up on exceptions to prevent server crashes and memory
leaks on exceptions.
I will check in my code, so that will give you a head start. And I
except that a simple code review and addition of try blocks at
appropriate places will identify the issues.
Thanks,
-Steve
On 5/7/2013 1:35 AM, Razequl Islam wrote:
> Hi Steve,
> I also want to have a look at the possible problem. I am trying to set
> up the environment on my machine. I have the previous version. What do I
> need to do to get 2.0 working? Should I set up the environment from the
> scratch or should an update will do. Please let me know how I should
> proceed. I can also do the debugging once I have the environment in place.
> Thanks.
> - Razequl
> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
> Hi Razequl,
> I have been trying to integrate your bidirectional shortest path
> code. I have merged the code into my pgrouting branch
> "sew-devel-2_0", but it is crashing the back-end with a segv.
> If you have time and want to look into this that would be great as I
> would like to get this code working in 2.0.
> I'm not sure if I found a bug in your code or I broke something when
> I merged it, or for that matter that I even merged the correct code
> :) because you sent email indicating that you fixed stuff. I merged
> the code from master at https://github.com/zibon/__pgrouting
> <https://github.com/zibon/pgrouting>
> I also ran into an issue that when I merged you code into the code
> library, that the trsp broke, then take you code out and it works
> again. I assume that there is some kind of function name or global
> initialization issue. This does not seem to be an issue for trsp now
> that the bi-dir code is in a separate library.
> This might give you a chance to get your development/test/debug
> environment setup and to familiarize yourself with the new source
> code layout.
> Let me know if you have time and I'll help point the way. If you are
> tied up with class work, etc that clearly takes priority.
> Thanks,
> -Steve
More information about the pgrouting-dev
