[pgrouting-dev] New TSP API
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 19 06:16:14 PDT 2013
Hi Dave, et al,
One of the stumbling blocks I have have had with creating a new API for
TSP is how we should pass the distance matrix. So I have been thinking
of something like this:
select * from pgr_tsp(matrix <type>, num integer, start integer);
The matrix type could be text for a SQL query that would return num rows
of num float8 or it could be float8[][] that is [num][num] elements. And
I support with a little extra work I could support both of these.
I'm not interested in computing the distance matrix because I will not
be able to do it "right" for any given use case and it limits how people
can use the function.
Thoughts?
-Steve
More information about the pgrouting-dev
