[pgrouting-dev] New TSP API
Daniel Kastl daniel at georepublic.de
Sun May 19 07:58:35 PDT 2013
>> SELECT * FROM pgr_tsp( 'SELECT id, start, end, cost FROM distances,
>> origin int [, destination int])
> I can do this, so each record is one cell. What are "start" and "end"? are
> these vertex ids or are they indices? Does the use KNOW that they need to
> also have a row for (end,start) as well as (start,end)? These things are
> less obvious and there for have more room for errors.
Well start and end is just "id1" and "id2".
You could actually also have two costs there, one for each direction (like
cost and reverse_cost).
> I suppose we could write an aggregate function that takes your query and
> returns matrix[][]. But we still need to define how to deal with null
> values in the matrix.
I know I said "matrix", but actually I didn't think about matrix ;-)
I thought about pairs of id's with cost(s). So it wouldn't be an [m][m]
matrix but more like a table with m*m/2 records (if there is a cost for
each direction for each combination).
I don't know how it should be later internally for the algorithm, but I
would say, that a query (table) always has a fix number of columns and a
variable number of rows.
In the end this would look like a graph, where all nodes are connected with
all nodes.
> select pgr_makematrix(i, j, cost) from
>     (select start as i, end as j, cost from distances) as foo;
> Then this could be passed as the SQL to the TSP. We need to keep each
> function simple and make them chainable or we limit the usefulness of them.
Exactly ;-)
> Any thoughts on how to deal with NULLs in the matrix?
> We could have some default rules like?
> 1. if the null is on a diagonal set it to zero
> 2. if the cell(i,j) is null and cell(j,i) is not use cell(j,i)
> 3. otherwise report an error
If you always have pairs A <-> B then you won't have a diagonal set.
In case there is no way in one direction (maybe even in both directions),
then this could be -1 for example?
Then it would be same as negative cost for Dijkstra or Astar and it won't
be taken into account.
Daniel
> Thoughts?
> -Steve
>  ... which would return the matrix in an optimized order.
>> I think it would be nice to be able to set origin and destination point.
>> But destination could be optional.
>> Daniel
>>     I'm not interested in computing the distance matrix because I will
>>     not be able to do it "right" for any given use case and it limits
>>     how people can use the function.
>>     Thoughts?
>>     -Steve
>>     ______________________________**___________________
>>     pgrouting-dev mailing list
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>     <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@**georepublic.de<daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130519/9fb2bd21/attachment.html>
More information about the pgrouting-dev mailing list
