[pgrouting-dev] New TSP API
Stephen Woodbridge
woodbri at swoodbridge.com
Sun May 19 09:25:03 PDT 2013
OK, so both you an Daniel are looking at the problem from some higher
level than I am dealing with. So we will have to build some layers to
bridge the gap between that and the low level code that I have to deal with.
The solver takes as arguments:
num - the size of the matrix
matrix - a num*num array of float8
and returns an array of num indices which it the optimal order.
This will be very close to the first API I create. At this level it
needs to be this simple. At a higher level some one can map ids to array
indexes and map them back again.
Regarding, null cell values or negative cell values, I guess I can set
them to infinity. I'm not going to try and modify the algorithm to
eliminate arbitrary rows.
Postgresql supports an an array type and multi-dimensional arrays. Most
people do not use them, but it is a convenient type for passing the data
to this algorithm.
If I can get this to work, then we can look at layering something
smarter on top of that.
The bottom line is if your data can not be put into a distance matrix
then you do not have a problem that can be solved by TSP. Now we just
need to make it easier to put the data into a distance matrix.
-Steve
On 5/19/2013 11:39 AM, Dave Potts wrote:
> Hi,
> Is there any sort of time tablethisn idea?
> I must admit, I have a need for this type of thing and with out looking
> at the existing code its difficult to comment.
> Due to the nature of the data that I am working with every node has
> its set of data, so I prefer a solution that uses a generic sql
> expression as a parmeter i.e. something like
> select target,cost,reverse_cost, etc where source =XXXXX
> Where XXXXX is a supply argument that gets provided invoked when data is
> need.
> Dave.
> On 19/05/13 15:58, Daniel Kastl wrote:
>> SELECT * FROM pgr_tsp( 'SELECT id, start, end, cost FROM
>> distances,
>> origin int [, destination int])
>> I can do this, so each record is one cell. What are "start" and
>> "end"? are these vertex ids or are they indices? Does the use KNOW
>> that they need to also have a row for (end,start) as well as
>> (start,end)? These things are less obvious and there for have more
>> room for errors.
>> Well start and end is just "id1" and "id2".
>> You could actually also have two costs there, one for each direction
>> (like cost and reverse_cost).
>> I suppose we could write an aggregate function that takes your
>> query and returns matrix[][]. But we still need to define how to
>> deal with null values in the matrix.
>> I know I said "matrix", but actually I didn't think about matrix ;-)
>> I thought about pairs of id's with cost(s). So it wouldn't be an
>> [m][m] matrix but more like a table with m*m/2 records (if there is a
>> cost for each direction for each combination).
>> I don't know how it should be later internally for the algorithm, but
>> I would say, that a query (table) always has a fix number of columns
>> and a variable number of rows.
>> In the end this would look like a graph, where all nodes are connected
>> with all nodes.
>> select pgr_makematrix(i, j, cost) from
>> (select start as i, end as j, cost from distances) as foo;
>> Then this could be passed as the SQL to the TSP. We need to keep
>> each function simple and make them chainable or we limit the
>> usefulness of them.
>> Exactly ;-)
>> Any thoughts on how to deal with NULLs in the matrix?
>> We could have some default rules like?
>> 1. if the null is on a diagonal set it to zero
>> 2. if the cell(i,j) is null and cell(j,i) is not use cell(j,i)
>> 3. otherwise report an error
>> If you always have pairs A <-> B then you won't have a diagonal set.
>> In case there is no way in one direction (maybe even in both
>> directions), then this could be -1 for example?
>> Then it would be same as negative cost for Dijkstra or Astar and it
>> won't be taken into account.
>> Daniel
>> Thoughts?
>> -Steve
>> ... which would return the matrix in an optimized order.
>> I think it would be nice to be able to set origin and
>> destination point.
>> But destination could be optional.
>> Daniel
>> I'm not interested in computing the distance matrix
>> because I will
>> not be able to do it "right" for any given use case and it
>> limits
>> how people can use the function.
>> Thoughts?
>> -Steve
>> _________________________________________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> <mailto:pgrouting-dev at lists.osgeo.org>
>> <mailto:pgrouting-dev at lists.osgeo.org>>
>> http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> <mailto:daniel.kastl at georepublic.de>
>> <mailto:daniel.kastl at georepublic.de>>
>> Web: http://georepublic.de <http://georepublic.de/>
>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
More information about the pgrouting-dev
