[pgrouting-dev] [OSRM-talk] Making progress on dumping pgRouting tables to OSRM
Daniel Kastl
daniel at georepublic.de
Thu Nov 14 18:55:35 PST 2013
On Fri, Nov 15, 2013 at 11:25 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Antonio,
> Thank you for the feedback on CURL, and the other references.
> I kind of look at the development path as get it working then figure out
> how to make it fast. Get it working allows use to validate the approach,
> but having feedback like this is great so we can avoid the same issues
> others have already discovered.
> I'll have to read up on the apache httpclient stuff. I have never seen
> that before.
> Did you write a wrapper for your requests to OSRM via httpclient? Can you
> share that?
Hi Steve,
I just remember Paul's HTTP client for PostgreSQL:
https://github.com/pramsey/pgsql-http
So here is some use case now ;)
But it seems it uses curl.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131115/26073a18/attachment.html>
More information about the pgrouting-dev
