[pgrouting-dev] shortest_path using nodes instead of ways
cathal coffey coffey.cathal at gmail.com
Sun Oct 27 15:03:16 PDT 2013
I want to compute the shortest path between two points
origin=(34.052299,-118.1812657) and destination: (34.141132,-117.853179).
Here is what I tried to do.
*Step 1:* Find the nearest nodes.
*origin: the following returns 590279764*
SELECT id
FROM nodes
ORDER BY st_distance(the_geom, st_setsrid(st_makepoint(-118.1812657,
34.052299), 4326))
LIMIT 1
*destination: the following returns 123007528*
SELECT id
FROM nodes
ORDER BY st_distance(the_geom, st_setsrid(st_makepoint(-117.853179,
34.141132), 4326))
LIMIT 1
*Step 2:* Compute shortest path between origin and destination.
SELECT *
FROM pgr_dijkstra(
'SELECT gid as id, source, target, length AS cost FROM ways',
 590279764, 123007528, false, false
However when I execute this I get the following error.
ERROR:  Start vertex was not found.
********** Error **********
SQL state: XX000
Why is this happening?
Kind regards,
Cathal
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131027/5976eda4/attachment.html>
More information about the pgrouting-dev mailing list
