[pgrouting-dev] [postgis-devel] [OT] postgresql raise notice isgiving me a major headache
Paragon Corporation lr at pcorp.us
Fri Sep 6 01:03:08 PDT 2013
Actually the numbers are different between 64-bit and 32-bit so I guess it's
the other issue you mentioned about a bit related
I do have notices disabled.
Breakdown is
pg9.3w32 : 'z_crash' => 0,
           'z_fail' => 0,
           'z_pass' => 65
pg9.3 w64:  'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 64
pg9.2w32:  'z_crash' => 0,
           'z_fail' => 0,
           'z_pass' => 65
 pg9.2w64:  'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 64
Pg 9.1w64:    'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 64
-----Original Message-----
[mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Friday, September 06, 2013 2:55 AM
To: 'PostGIS Development Discussion'
Cc: 'pgRouting Dev List'
Subject: Re: [pgrouting-dev] [postgis-devel] [OT] postgresql raise notice
Steve,
I presume the differences in errors I'm seeing on winnie are because of the
notice issue.
pg 9.3    'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 64
pg 9.2
           'z_crash' => 0,
           'z_fail' => 4,
           'z_pass' => 61
pg 9.1
            'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 64
I haven't looked closely at them to see. I thought I had notice checking
disabled though so perhaps something different since I do recall Before they
were all passing.
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Thursday, September 05, 2013 6:58 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] [OT] postgresql raise notice is giving me a
major headache
Not really, you can see that we had to write our own regression harness
(run_test) as soon as we supported multiple versions of PgSQL.
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Thursday, September 5, 2013 at 3:51 PM, Stephen Woodbridge wrote:
> Hi all,
> We have a bunch of functions in pgrouting that output a lot of
> informational NOTICE messages to the user.
> In our automated tests, we collect the command output and compare it to
> a reference file. The headache is the no two versions of postgresql
> output the same format for these messages. So a lot of our test fail
> with false positive errors. We are testing on pg versions 9.0, 9.1 and
> 9.2 and I guess we should be adding 9.3 soon also.
> I guess the obvious answer is to not compare the notice messages. But I
> don't like that answer.
> Any better thoughts on this?
> -Steve
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
pgrouting-dev mailing list
pgrouting-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
