[pgrouting-dev] dealing with memory issues in home developed code
Dave Potts dave.potts at pinan.co.uk
Tue Sep 24 15:16:03 PDT 2013
On 24/09/13 11:03, Sandro Santilli wrote:
> On Tue, Sep 24, 2013 at 08:26:45AM +0200, Dave Potts wrote:
>> I seem to have a memory issue in some code I am writing for c/c++
>> pg-route project.  From the way that the code is behaving I seem to
>> have a memory heap/corruption problem.  Is there an easy way of
>> using something like the electric fence or other memory checker on a
>> pg route module or does the entire postgres database need to be
>> recompiled?
> No need to recompile, check out
> http://blog.cleverelephant.ca/2008/08/valgrinding-postgis.html
> But if you're not afraid of recompiling, consider also this one:
> http://wiki.postgresql.org/wiki/Valgrind
Thanks Sandro, got it sorted.
> --strk;
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
