[pgrouting-dev] Can the manual be forked?
Daniel Kastl daniel at georepublic.de
Thu Apr 3 04:11:16 PDT 2014
Hi Luís,
Thanks a lot for your offer!
Yes, everything is available on Github, so you could just fork the
repository and then submit a pull request with your changes.
There are several sources:
   - If you want to change something on the website:
   https://github.com/pgrouting/website
   - If you want to change the documentation (http://docs.pgrouting.org/),
   then the relevant source files are within the pgRouting repository:
   https://github.com/pgRouting/pgrouting
See also: https://github.com/pgRouting/pgrouting/wiki#documentation
If you have more questions, feel free to ask.
Daniel
On Thu, Apr 3, 2014 at 4:13 PM, Luís de Sousa <luis.a.de.sousa at gmail.com>wrote:
> Hello everyone,
> Is the manual (pdf document) available at GitHub? There a few things I
> would like to correct. Regards,
> Luís
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140403/8574742c/attachment.html>
More information about the pgrouting-dev mailing list
