[pgrouting-dev] Jenkins issues for pgRouting
Paragon Corporation lr at pcorp.us
Tue Apr 15 13:10:30 PDT 2014
 Hmm I checked the 9.3 w32 and that one actually all tests pass, so I guess
it's not 9.3 that is the culprit for the 9.3 w64 failure
'doc/test/bdstar-any.test' => 'FAILED: 1,5c1 < 0|4|3|0 < 1|3|5|1 < 2|6|11|1
< 3|11|12|0 < 4|10|-1|0
> ERROR:  Error computing path: Path Not Found',
I know we had patched up 9.3 before pgRouting 2.0 release unless new c files
have been added since.
-----Original Message-----
Sent: Tuesday, April 15, 2014 4:07 PM
To: 'Stephen Woodbridge'; 'PostGIS Development Discussion'
Subject: RE: Jenkins issues for pgRouting
Steve,
Should be more or less fixed now (had to remove jenkins git build tagging
parameter).  I have to rerun against latest PostGIS 2.1 branch to be
completely sure.
But I got a clean run through with the current configs and binaries are now
up to date.
Sorry about that.
On the 9.3 one of the tests fails - but you might know about that based on
your last comment.
Output from 9.3 w64
RUNNING: test-runner.pl -pgisver 2.1.1dev -pgport 10442 -ignorenotice CREATE
EXTENSION CREATE EXTENSION Processing test: sampledata
    test run time: 0.749999
Processing test: alphashape-any
    test run time: 0.441176
Processing test: apspJohnson-any
    test run time: 0.433649
Processing test: apspWarshall-any
    test run time: 0.431095
Processing test: astar-any
    test run time: 0.428121
Processing test: bdstar-any
    test run time: 0.434793
Processing test: bdDijkstra-any
    test run time: 0.440041
Processing test: dijkstra-any
    test run time: 0.431643
Processing test: drivingDistance-any
    test run time: 0.427566
Processing test: pointsAsPolygon-any
    test run time: 0.443343
Processing test: kdijkstra-any
    test run time: 0.431488
Processing test: tsp-any
    test run time: 0.640546
Processing test: trsp-any
    test run time: 0.443666
Processing test: utilities-any
    test run time: 0.415544
Processing test: createTopology-any
    test run time: 3.390554
Processing test: createVertTab-any
    test run time: 2.296786
Processing test: analyzeGraph-any
    test run time: 3.406149
Processing test: analyzeOneway-any
    test run time: 0.53116
Processing test: nodeNetwork-any
    test run time: 1.734296
Processing test: apsp_johnson-any-00
    test run time: 0.430401
Processing test: apsp_warshall-any-00
    test run time: 0.422256
Processing test: spas-any-00
    test run time: 0.441688
Processing test: spas-any-01
    test run time: 0.427507
Processing test: bd_astar-any-01
    test run time: 0.490234
Processing test: bd_astar-any-02
    test run time: 0.478431
Processing test: bd_astar-any-03
    test run time: 0.484699
Processing test: bd_astar-any-04
    test run time: 0.483892
Processing test: bd_astar-any-05
    test run time: 0.489346
Processing test: bd_astar-any-06
    test run time: 0.494877
Processing test: bd_dijkstra-any-01
    test run time: 0.483413
Processing test: bd_dijkstra-any-02
    test run time: 0.482507
Processing test: bd_dijkstra-any-03
    test run time: 0.47046
Processing test: bd_dijkstra-any-04
    test run time: 0.478638
Processing test: bd_dijkstra-any-05
    test run time: 0.489954
Processing test: bd_dijkstra-any-06
    test run time: 0.481569
Processing test: versionless-any-01
    test run time: 0.515627
Processing test: common-any-01
    test run time: 0.718669
Processing test: common-any-02
    test run time: 0.843678
Processing test: common-any-03
    test run time: 0.78118
Processing test: common-any-04
    test run time: 1.500002
Processing test: common-any-05
    test run time: 0.796779
Processing test: createTopology-any-01
    test run time: 8.687432
Processing test: createVerticesTable-any-01
    test run time: 5.46865
Processing test: gettablename-any-01
    test run time: 1.843642
Processing test: pgrouting_conversion_tools-any-01
    test run time: 0.474763
Processing test: pgrouting_dmatrix_tools-any-01
    test run time: 0.509414
Processing test: spd-any-00
    test run time: 0.42761
Processing test: spd-any-01
    test run time: 0.430564
Processing test: spd-any-02
    test run time: 0.428659
Processing test: spd-any-03
    test run time: 0.427396
Processing test: spd-any-04
    test run time: 0.431823
Processing test: drivingdistance-any-00
    test run time: 0.453126
Processing test: kdijkstra-any-01
    test run time: 0.437391
Processing test: kdijkstra-any-02
    test run time: 0.431589
Processing test: kdijkstra-any-03
    test run time: 0.443252
Processing test: vidstodmatrix-any-01
    test run time: 0.434415
Processing test: vidstodmatrix-any-02
    test run time: 0.424792
Processing test: ksp-any-01
    test run time: 0.439074
Processing test: ksp-any-02
    test run time: 0.435601
Processing test: trsp-any-00
    test run time: 0.433208
Processing test: trsp-any-01
    test run time: 0.44172
Processing test: trsp-any-02
    test run time: 0.430705
Processing test: trsp-any-03
    test run time: 0.428514
Processing test: trsp_vias-any-04
    test run time: 0.439085
Processing test: tsp-any-00
    test run time: 0.562501
Processing test: tsp-any-01
    test run time: 0.515551
Processing test: tsp-any-03
    test run time: 1.062418
Processing test: tsp-any-04
    test run time: 0.499916
Processing test: tsp-any-05
    test run time: 0.531171
$stats = {
           'doc/test/test.conf' => [
                                       'comment' => 'documentation SQL tests
for any versions.',
                                       'doc/test/alphashape-any.test' =>
'Passed',
                                       'doc/test/analyzeGraph-any.test' =>
'Passed',
                                       'doc/test/analyzeOneway-any.test' =>
'Passed',
                                       'doc/test/apspJohnson-any.test' =>
'Passed',
                                       'doc/test/apspWarshall-any.test' =>
'Passed',
                                       'doc/test/astar-any.test' =>
'Passed',
                                       'doc/test/bdDijkstra-any.test' =>
'Passed',
'FAILED: 1,5c1 < 0|4|3|0 < 1|3|5|1 < 2|6|11|1 < 3|11|12|0 < 4|10|-1|0
                                       'doc/test/createTopology-any.test' =>
'Passed',
                                       'doc/test/createVertTab-any.test' =>
'Passed',
                                       'doc/test/dijkstra-any.test' =>
'Passed',
                                       'doc/test/drivingDistance-any.test'
=> 'Passed',
                                       'doc/test/kdijkstra-any.test' =>
'Passed',
                                       'doc/test/nodeNetwork-any.test' =>
'Passed',
                                       'doc/test/pointsAsPolygon-any.test'
=> 'Passed',
                                       'doc/test/sampledata.test' =>
'Passed',
                                       'doc/test/trsp-any.test' => 'Passed',
                                       'doc/test/tsp-any.test' => 'Passed',
                                       'doc/test/utilities-any.test' =>
'Passed'
           'src/apsp_johnson/test/test.conf' => [
                                                    'comment' => 'APSP
Johnson test for any versions.',
'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
           'src/apsp_warshall/test/test.conf' => [
                                                     'comment' => 'APSP
Warshall test for any versions.',
'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
           'src/astar/test/test.conf' => [
                                             'comment' => 'astar test for
any versions.',
'src/astar/test/spas-any-00.test' => 'Passed',
'src/astar/test/spas-any-01.test' => 'Passed'
           'src/bd_astar/test/test.conf' => [
                                                'comment' => 'Bi-directional
AStar test for any versions.',
'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
           'src/bd_dijkstra/test/test.conf' => [
                                                   'comment' =>
'Bi-directional Dijkstra test for any versions.',
'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
           'src/common/test/test.conf' => [
                                              'comment' =>
'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any
versions.',
'src/common/test/common-any-01.test' => 'Passed',
'src/common/test/common-any-02.test' => 'Passed',
'src/common/test/common-any-03.test' => 'Passed',
'src/common/test/common-any-04.test' => 'Passed',
'src/common/test/common-any-05.test' => 'Passed',
'src/common/test/createTopology-any-01.test' => 'Passed',
'src/common/test/createVerticesTable-any-01.test' => 'Passed',
'src/common/test/gettablename-any-01.test' => 'Passed',
'src/common/test/pgrouting_conversion_tools-any-01.test' => 'Passed',
'src/common/test/pgrouting_dmatrix_tools-any-01.test' => 'Passed',
'src/common/test/versionless-any-01.test' => 'Passed'
           'src/dijkstra/test/test.conf' => [
                                                'comment' => 'Dijkstra test
for any versions.',
'src/dijkstra/test/spd-any-00.test' => 'Passed',
'src/dijkstra/test/spd-any-01.test' => 'Passed',
'src/dijkstra/test/spd-any-02.test' => 'Passed',
'src/dijkstra/test/spd-any-03.test' => 'Passed',
'src/dijkstra/test/spd-any-04.test' => 'Passed'
           'src/driving_distance/test/test.conf' => [
                                                        'comment' =>
'Driving Distance test for any versions.',
'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
           'src/kdijkstra/test/test.conf' => [
                                                 'comment' => 'KDijkstra
'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-03.test' => 'Passed',
'src/kdijkstra/test/vidstodmatrix-any-01.test' => 'Passed',
'src/kdijkstra/test/vidstodmatrix-any-02.test' => 'Passed'
           'src/ksp/test/test.conf' => [
                                           'comment' => 'KSP test for any
versions.',
                                           'src/ksp/test/ksp-any-01.test' =>
'Passed',
                                           'src/ksp/test/ksp-any-02.test' =>
'Passed'
           'src/trsp/test/test.conf' => [
                                            'comment' => 'TRSP test for any
versions.',
                                            'src/trsp/test/trsp-any-00.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-01.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-02.test'
=> 'Passed',
                                            'src/trsp/test/trsp-any-03.test'
=> 'Passed',
'src/trsp/test/trsp_vias-any-04.test' => 'Passed'
           'src/tsp/test/test.conf' => [
                                           'comment' => 'TSP test for any
versions.',
                                           'src/tsp/test/tsp-any-00.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-01.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-03.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-04.test' =>
'Passed',
                                           'src/tsp/test/tsp-any-05.test' =>
'Passed'
           'z_crash' => 0,
           'z_fail' => 1,
           'z_pass' => 68
Regina
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Tuesday, April 15, 2014 2:54 PM
To: PostGIS Development Discussion
Cc: Paragon Corporation
Subject: Jenkins issues for pgRouting
Hi Regina,
It looks like Jenkins is having some heart burn with pgRouting. Can you
please take a look when you have a few minutes.
http://winnie.postgis.net:1500/job/pgRouting_matrix_branch_2.0/55/console
Let me know if I need to do something from my end.
Thanks,
   -Steve
More information about the pgrouting-dev mailing list
