[pgrouting-dev] Optimal Meeting Point (OMP)
Daniel Kastl daniel at georepublic.de
Thu Jul 17 02:09:43 PDT 2014
Hi Louis,
A few weeks ago I wrote down this memo:
https://gist.github.com/dkastl/11376623
I don't know it's still working but it should. It contains all the packages
you need to build pgRouting on Ubuntu 14.04
Let me know, if something doesn't work anymore.
Daniel
On Thu, Jul 17, 2014 at 9:59 AM, Luís de Sousa <luis.a.de.sousa at gmail.com>
wrote:
> Hello everyone,
> I am following the Wiki to set up a development environment, but compiling
> pgRouting is becoming a bit of a saga. Right now I am stuck with cmake
> unable to find Boost:
> CMake Error at /usr/share/cmake-2.8/Modules/FindBoost.cmake:1131 (message):
>   Unable to find the requested Boost libraries.
>   Boost version: 1.54.0
>   Boost include path: /usr/include
>   Could not find the following Boost libraries:
>           boost_thread
>           boost_system
>   No Boost libraries were found.  You may need to set BOOST_LIBRARYDIR to
> the
>   directory containing Boost libraries or BOOST_ROOT to the location of
>   Boost.
> Call Stack (most recent call first):
>   cmake/FindCGAL.cmake:42 (find_package)
>   CMakeLists.txt:303 (find_package)
> I am on Ubuntu 14.04. A few outputs from my system:
> $ dpkg -l | grep boost
> ii  libboost-date-time1.54.0:amd64
> 1.54.0-4ubuntu3.1                                   amd64        set of
> date-time libraries based on generic programming concepts
> ii  libboost-dev
> 1.54.0.1ubuntu1                                     amd64        Boost C++
> Libraries development files (default version)
> ii  libboost-graph-dev:amd64
> 1.54.0.1ubuntu1                                     amd64        generic
> graph components and algorithms in C++ (default version)
> ii  libboost-graph1.54-dev:amd64
> 1.54.0-4ubuntu3.1                                   amd64        generic
> ii  libboost-graph1.54.0:amd64
> ii  libboost-iostreams-dev:amd64
> Boost.Iostreams Library development files (default version)
> ii  libboost-iostreams1.54-dev:amd64
> ii  libboost-iostreams1.54.0:amd64
> ii  libboost-regex1.54-dev:amd64
> 1.54.0-4ubuntu3.1                                   amd64        regular
> expression library for C++
> ii  libboost-regex1.54.0:amd64
> ii  libboost-serialization1.54-dev:amd64
> serialization library for C++
> ii  libboost-serialization1.54.0:amd64
> ii  libboost-system1.54.0:amd64
> 1.54.0-4ubuntu3.1                                   amd64        Operating
> system (e.g. diagnostics support) library
> ii  libboost-test1.54-dev:amd64
> 1.54.0-4ubuntu3.1                                   amd64        components
> for writing and executing test suites
> ii  libboost-test1.54.0:amd64
> ii  libboost-thread1.46.1
> 1.46.1-7ubuntu3                                     amd64        portable
> C++ multi-threading
> ii  libboost1.54-dev
> 1.54.0-4ubuntu3.1                                   amd64        Boost C++
> $ locate boost_thread
> /usr/lib/libboost_thread.so.1.46.1
> $ locate boost_system
> /usr/lib/x86_64-linux-gnu/libboost_system.so.1.54.0
> $ whereis boost
> boost: /usr/include/boost
> $ cat /etc/environment | grep BOOST
> BOOST_LIBRARYDIR="/usr/lib/x86_64-linux-gnu/:/usr/lib/"
> BOOST_ROOT="/usr/include/boost"
> Any ideas on why isn't cmake finding Boost? Thank you,
> Luís
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140717/afe342bd/attachment.html>
More information about the pgrouting-dev mailing list
