[pgrouting-dev] Boost graph algorithm
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 10 05:55:16 PDT 2014
On 3/10/2014 6:52 AM, Adrien ANDRÉ wrote:
> Hi,
> Stephen, thank you for your answer.
> Despite not being at ease with tools as Git and CMake or C/C++
> development and compilation, i began following steps you described.
Yes, there are a lot of moving pieces to get your head around. They are
supposed to make things easier in the long run but the upfront learning
curve can be pretty steep at times. Ask if you get stuck and there are a
bunch of us here that will jump in with ideas and help.
> Here is the new branch:
> https://github.com/adrienandrem/pgrouting/tree/components
This is the right place to start.
> I've noticed the
> https://github.com/pgRouting/pgrouting/wiki/Developer---Getting-Started
> page, and will keep you informed of my progress.
Great! I look forward to more reports and/or questions as you progress.
Thanks,
   -Steve
> Regards,
> Adrien
> On 26/02/2014 11:52, Stephen Woodbridge wrote:
>> On 2/26/2014 9:22 AM, Adrien ANDRÉ wrote:
>>> Hi all,
>>> prior to routing, i'd like to extract connected components from my
>>> network.
>>> Reading the mailing list i've learned this algorithm is implemented in
>>> the boost graph library.
>>> Could you tell me what are the main steps to make this algorithm
>>> available from my database?
>>> Or, could you advise me an existing tutorial about this?
>> Hi Adrien,
>> On the wiki are some pages on development and getting started.
>> Basically the process we use is to have people look at pgr_dijkstra()
>> function as this is pretty simple and it uses boost.
>> src/dijkstra and clone this into your own directory
>> Update the CMakeLists.txt file here and below and change the name of the
>> files to your algorithm
>> src/dijkstra/doc -- is for your doc files
>> src/dijkstra/sql -- is the code the links the sql function to the C/C++
>> code
>> src/dijkstra/src -- is you C/C++ code
>> src/dijkstra/test -- are your test files for the automated test system
>> src/dijkstra/tester -- can be used to write a command lin test tool that
>> test your code outside of the database
>> Jump right in and ask questions when you are confused or need help.
>> Oh, I recommend that you go to github and fork the pgrouting project
>> into your account, then clone you fork, and create a branch off of
>> master or develop and do you development in that branch. Then when you
>> have code to submit back you can generate a pull request that is easy
>> for us or other to merge back into the main development branch.
>> Thanks,
>>    -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
