[pgrouting-dev] GTFS routing in PgRouting 2
Daniel Kastl
daniel at georepublic.de
Mon Sep 15 08:08:49 PDT 2014
Hi Valery,
The multimodal routing was a Google Summer of Code project before pgRouting
2.0 was released.
As Steve said, it would take some effort to include it into the next
release, because we have now some rules defined, ie. how to add tests,
documentation, etc..
Various people have told me already how good it would be to have
multi-modal routing with GTFS, but someone had to fund this or contribute
to it.
Regards,
Daniel
On Mon, Sep 15, 2014 at 7:13 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 9/15/2014 5:21 AM, Valery N. wrote:
>> Hi,
>> Sry if it was discussed before - I'm quite newbe in this Maillist.
>> The reason of mail qute simple: Defenetly PgRouting - amazing engine for
>> routing. Due my interests I investigate possibility to make route just
>> only via GTFS data and find one related articre:
>> https://github.com/pgRouting/pgrouting/wiki/MMPTR-Tutorial
>> Unfortuntaly as I can see - it's most related to PGrouting 1.x branch
>> with some magic extras like:
>> |\i /usr/share/pgrouting/routing_transit.sql
>> \i /usr/share/pgrouting/routing_transit_wrappers.sql|
>> and calling procedures from this magic extras:
>> SELECT prepare_scheduled('gtfs');
>> So my question is quite simpe: if someone have experience to make GTFS
>> routing using PgRoute 2.x branch ?
> Add a ticket to the bug tracker and we will consider it for 2.1 but we
> don't currently have a schedule for that so that won'n help in the sort
> term.
> If your interested in getting into a little coding you could fork
> pgrouting, read the wiki about development and try porting the old cold
> into the 2.0 src tree. Then issue a pull request.
> Thanks for reporting this issue.
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140915/6e96b398/attachment.html>
More information about the pgrouting-dev
