[pgrouting-dev] Regarding BFS Visitor
Sankepally Rohith Reddy
rohith.reddy at research.iiit.ac.in
Mon Aug 24 23:44:02 PDT 2015
Hey Vicky,
Thanks for your reply.I got what you said.As given in the source code,at different points of the algorithm,the different methods of the visitor class are being called.Let us consider one of the methods of bfs_visitor class(as given in the source code) ,
template <class Vertex, class Graph>
graph::bfs_visitor_event_not_overridden
examine_vertex(Vertex u, Graph& g)
invoke_visitors(m_vis, u, g, ::boost::on_examine_vertex());
return graph::bfs_visitor_event_not_overridden();
which is being called when a vertex is examined(popped out of the queue) in the algorithm.Please help me with the following questions: What does the function invoke_visitors() actually do? What exactly does the fourth argument of the function invoke_visitors mean? What exactly does the method(namely examine_vertex) return?
Thanks in advance.
----- Original Message -----
From: "Vicky Vergara" <vicky_vergara at hotmail.com>
To: "pgrouting-dev" <pgrouting-dev at lists.osgeo.org>
Sent: Tuesday, August 25, 2015 1:07:08 AM
Subject: Re: [pgrouting-dev] Regarding BFS Visitor
You might want to read the visitor concept of the boost libraries
http://www.boost.org/doc/libs/1_59_0/libs/graph/doc/visitor_concepts.html
but the general idea is that an algorithm has several places that can be visited:
hope this pseudo code helps:
foo_algorithm()
1 do_a()
2 do_users_visitors_code_0()
3 if (cond) then
4 do_c()
5 do_users_visitor_code_1()
6 else
7 do_d()
8 do_users_visitor_code_2()
9 endif
> Date: Mon, 24 Aug 2015 23:02:14 +0530
> From: rohith.reddy at research.iiit.ac.in
> To: pgrouting-dev at lists.osgeo.org
> Subject: [pgrouting-dev] Regarding BFS Visitor
> Hello there,
> Recently I started using pgrouting,and was curious to know about how different algorithms were being implemented.While going through the source code of breadth_first_search.hpp(http://www.boost.org/doc/libs/1_58_0/boost/graph/breadth_first_search.hpp),I came across the class named bfs_visitor.In every function of the visitor class I noticed a function named invoke_visitors().I explored about this,but couldnt understand,what this function does and how it was being implemented.Can anyone help me with this?
> Thanks in advance.
> pgrouting-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev
