[pgrouting-dev] How do I work on pgRouting documentation?
    Daniel Kastl
    daniel at georepublic.de
    Sun Jul 10 07:42:06 PDT 2016
This is my own memo how to build pgRouting with documentation, and how to
publish it to GH-Pages and Transifex:
https://gist.github.com/dkastl/5617030
Vicky did the documentation updates in the past months, so I'm not sure all
dependencies and commands are still 100% the same with newer versions of
Ubuntu for example.
But I just run this part and it worked for me:
https://gist.github.com/dkastl/5617030#file-build_pgrouting-sh-L9-L13heers
At least "html" worked for me. It seems PDF generation has errors.
Cheers,
Daniel
On Sun, Jul 10, 2016 at 11:16 PM, Worth Lutz <wal3 at mindspring.com> wrote:
> I tried all that and do not see where the updated documentation ends up.
> After doing the build, pointing to:
>     ~/pgrouting/build/doc/html/index.html
> does not seem to work for me. I'm obviously missing something.
> Thanks,
> *Worth Lutz*
> On 7/9/2016 10:06 AM, Daniel Kastl wrote:
> Sorry, should be "cmake" of course.
> ... auto correction...
> On Jul 9, 2016 11:05 PM, "Daniel Kastl" <daniel at georepublic.de> wrote:
>> The documentation is compiled with cake using a special compile flag, see
>> https://github.com/pgrouting/pgrouting/tree/develop#compilation
>> We probably need to make this easier to find in the documentation ;-)
>> Cheers,
>> Daniel
>> On Jul 9, 2016 9:15 PM, "Worth Lutz" <wal3 at mindspring.com> wrote:
>>> I have been side tracked a bit but have been reading the documentation
>>> extensively over the past week. I have had some success working with my
>>> data and will be rereading the docs to make sure my understanding is
>>> correct. I'll then commit the corrections and additions I'm working on.
>>> How do I run the docs locally.  I am familiar with Sphinx but have not
>>> found the place to
>>> *make html*
>>> I see a *make.bat* file but that is for Windows.  I normally work on
>>> Ubuntu and have a *Makefile* in the directory as well as *make.bat*. Is
>>> development normally done on Windows? And thus the *Makefile *removed
>>> when make.bat was edited?
>>> Thanks for your help.
>>> *Worth Lutz*
>>> On 7/8/2016 11:18 PM, Vicky Vergara wrote:
>>> I merged code and more documentation to develop.
>>> Here is a helpful link for keeping up to date the branches:
>>> http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
>>> On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara < <vicky at georepublic.de>
>>> vicky at georepublic.de> wrote:
>>>> Thanks
>>>> On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>> Vicky,
>>>>> My github is at:
>>>>>     https://github.com/worthlutz/pgrouting/
>>>>> The branch I'll be using is *doc-improvements* branched off *develop*.
>>>>> I'll let you know when I push some changes.
>>>>> *Worth Lutz*
>>>>> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>>>> Tell when you make the branch
>>>>> so I can pinpoint where to find the docuemtnation
>>>>> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>>> Thanks Vicky.  I'll let you know what I find.
>>>>>> *Worth Lutz*
>>>>>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>>>> Hello Worth Lutz.
>>>>>> The documentation changes you made them to master or to develop?
>>>>>> Right now develop documentation has changed, not in everything put it
>>>>>> has lots of changes.
>>>>>> <http://docs.pgrouting.org/dev/en/doc/index.html>
>>>>>> It is better for us to work on the develop branch which has the 2.3
>>>>>> documentation.
>>>>>> Its changing a lot. so to have the current contents of develop in
>>>>>> your for:
>>>>>> git checkout develop
>>>>>> git fetch upstream
>>>>>> git merge upstream/develop
>>>>>> git push
>>>>>> then in the github site you will be able to see that it contains the
>>>>>> current contents of develop.
>>>>>> Then you can branch to a working directory
>>>>>> git checkout -b 'improve/documentation'
>>>>>> then do a
>>>>>> git push
>>>>>> and give me the link to the branch in your repository so that if I
>>>>>> make changes to develop's documentation, I can make a pull request to your
>>>>>> branch with the changes I made.
>>>>>> Work on the documentation, and make pull requests to develop.
>>>>>> thanks.
>>>>>> Vicky from the pgRouting team
>>>>>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>>>>>> If I want to work on some errors/typos in the documentation, how do
>>>>>>> I do that?
>>>>>>> I've got a fork and want to create a pull request.
>>>>>>> Which branch should I be working on?
>>>>>>> As I'm starting a new routing project, I'm reading (and rereading)
>>>>>>> the documentation a lot and think I should fix what I find.
>>>>>>> *Worth Lutz*
>>>>>>> _______________________________________________
>>>>>>> pgrouting-dev mailing list
>>>>>>> <pgrouting-dev at lists.osgeo.org>pgrouting-dev at lists.osgeo.org
>>>>>>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>>>>> Georepublic UG (haftungsbeschränkt)
>>>>>> Salzmannstraße 44,
>>>>>> 81739 München, Germany
>>>>>> Vicky Vergara
>>>>>> Operations Research
>>>>>> eMail: vicky at georepublic.de
>>>>>> Web: https://georepublic.info
>>>>>> Tel: +49 (089) 4161 7698-1
>>>>>> Fax: +49 (089) 4161 7698-9
>>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>>> CEO: Daniel Kastl
>>>>>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>>> Salzmannstraße 44,
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> CEO: Daniel Kastl
>>>> Salzmannstraße 44,
>>>> Vicky Vergara
>>>> Operations Research
>>>> CEO: Daniel Kastl
>>> Salzmannstraße 44,
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160710/bfa31653/attachment-0001.html>
More information about the pgrouting-dev
