[pgrouting-dev] How do I work on pgRouting documentation?
Vicky Vergara
vicky at georepublic.de
Wed Jun 22 17:57:28 PDT 2016
Thanks
On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3 at mindspring.com> wrote:
> Vicky,
> My github is at:
> https://github.com/worthlutz/pgrouting/
> The branch I'll be using is *doc-improvements* branched off *develop*.
> I'll let you know when I push some changes.
> *Worth Lutz*
> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
> Tell when you make the branch
> so I can pinpoint where to find the docuemtnation
> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>> Thanks Vicky. I'll let you know what I find.
>> *Worth Lutz*
>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>> Hello Worth Lutz.
>> The documentation changes you made them to master or to develop?
>> Right now develop documentation has changed, not in everything put it has
>> lots of changes.
>> http://docs.pgrouting.org/dev/en/doc/index.html
>> It is better for us to work on the develop branch which has the 2.3
>> documentation.
>> Its changing a lot. so to have the current contents of develop in your
>> for:
>> git checkout develop
>> git fetch upstream
>> git merge upstream/develop
>> git push
>> then in the github site you will be able to see that it contains the
>> current contents of develop.
>> Then you can branch to a working directory
>> git checkout -b 'improve/documentation'
>> then do a
>> git push
>> and give me the link to the branch in your repository so that if I make
>> changes to develop's documentation, I can make a pull request to your
>> branch with the changes I made.
>> Work on the documentation, and make pull requests to develop.
>> thanks.
>> Vicky from the pgRouting team
>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>> If I want to work on some errors/typos in the documentation, how do I do
>>> that?
>>> I've got a fork and want to create a pull request.
>>> Which branch should I be working on?
>>> As I'm starting a new routing project, I'm reading (and rereading) the
>>> documentation a lot and think I should fix what I find.
>>> *Worth Lutz*
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160622/b1b28563/attachment-0001.html>
More information about the pgrouting-dev
