[pgrouting-dev] [Build errors ] Re: osm2pgrouting 2.1.0 Beta is available for testing
dave.potts at pinan.co.uk
Sun Mar 20 10:14:11 PDT 2016
Hi
Tried building this on Ubuntu 15.10 using g++ version 4.5.2.1 vers postgres 9.5
See the attached list of errors when building it
Dave.
20 March 2016 13:42, "Stephen Woodbridge" <woodbri at swoodbridge.com> wrote:
> Hi all,
> Vicky has released osm2pgrouting 2.1.0 Beta.
> You can read about it and download from here:
> https://github.com/pgRouting/osm2pgrouting/releases/tag/osm2pgrouting-2.1.0-beta
> The release starts refactoring the osm2pgrouting code. There are a lot of bug fixes and
> enhancements in this code. The link above also links to the issues that were closed.
> WE NEED YOUR HELP! Things that you can do:
> * please check any issues you reported against prior releases
> * download, compile, and try it out and report any issues that you find
> * Mac OS-X testing. This is important for someone to compile, install and make some simple tests.
> Our normal OS-X guru is busy and it would be great to get some confirmation that this is working.
> Please give us a helping hand with getting this release tested and out the door.
> Best regards,
> -Steve
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160320/43cc5003/attachment.obj>
More information about the pgrouting-dev
