[pgrouting-dev] [pgrouting-users] an implementation of beta skeletons, relative neighborhood graph and gabriel graphs
Daniel Kastl daniel at georepublic.de
Thu Mar 24 08:21:49 PDT 2016
I would also like to see more functions for network analysis.
pgRouting unfortunately has "routing" in its name, but it's already more
than that.
I think it would be nice to create an issue for each function.
Then, if someone wants to add the missing pieces, such as tests and
documentation, new functions could be added via pull request.
Daniel
On 25/03/16 00:14, Rémi Cura wrote:
> +1 for using pgRouting as a graph tools rather than traffic tool
> Cheers,
> Rémi-C
> 2016-03-24 16:07 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
>     Hi Dave,
>     I just looked at the wikipedia pages and these analysis look very
>     interesting. My primary focus is on vehicle routing so I'm not
>     sure I'm a good judge of their usefulness, but pgRouting has been
>     used for Max Flow Analysis and other not vehicle routing problems.
>     I've cc'd this to the user list to get a wider audience and see if
>     there is interest from other users in this kind of analysis.
>     Also if you put these in a github repository, I believe we have a
>     page in our wiki that points to other projects that might be
>     useful to pgRouting users. See Friends of pgRouting:
>     https://github.com/pgRouting/pgrouting/wiki#friends-of-pgrouting
>     -Steve
>     On 3/24/2016 10:51 AM, Stephen Woodbridge wrote:
>         -------- Forwarded Message --------
>         Subject:     Fwd: [pgrouting-dev] an implementation of beta
>         skeletons,
>         Date:     Tue, 22 Mar 2016 09:21:44 +0000
>         From:     dave.potts at pinan.co.uk <mailto:dave.potts at pinan.co.uk>
>         To:     woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>         Hi Steve,
>         Sorry to trouble you.
>         I email this to the development email list and did not get a
>         response.
>         I know that Beta skelton graphs are not a standard routing style
>         function but its the sort otf thing I use in my research which
>         is all
>         about network anaylsis.  I just wondered if anybody else did.
>         Dave.
>         -------- Forwarded message -------
>         <mailto:dave.potts at pinan.co.uk <mailto:dave.potts at pinan.co.uk>>
>         To: pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         Sent: 19 March 2016 17:28
>         Subject: [pgrouting-dev] an implementation of beta skeletons,
>         relative
>         Is there any interest in any off the above graph forms in the
>         routing
>         library?
>         See
>         https://en.wikipedia.org/wiki/Beta_skeleton
>         https://en.wikipedia.org/wiki/Relative_neighborhood_graph
>         https://en.wikipedia.org/wiki/Gabriel_graph
>         I have implementation with the following method signatures
>         CREATE OR REPLACE FUNCTION pgr_beta_skelton(sql text, beta
>         float,OUT id
>         integer ,OUT id1 integer , OUT id2 integer)
>             RETURNS SETOF RECORD AS
>               '$libdir/librouting-2.1', 'dir_graph_beta_skelton'
>               LANGUAGE c STABLE STRICT;
>         CREATE OR REPLACE FUNCTION pgr_relative_neigborhood_graph(sql
>         text ,OUT
>         id integer ,OUT id1 integer , OUT id2 integer)
>         'dir_graph_relative_neigborhood_graph'
>         CREATE OR REPLACE FUNCTION pgr_gabriel_graph(sql text ,OUT id
>         integer
>               '$libdir/librouting-2.1', 'dir_graph_gabriel_graph'
>         They all take an sql statement of the form
>         select  st_makeline(v1.the_geom,v2.the_geom) as the_geom  from
>            pgr_gabriel_graph('select id,st_x(the_geom) as x
>         ,st_y(the_geom) as y
>         from tmp_table2'), tmp_table2 v1, tmp_table2 v2 where
>         id1=v1.id <http://v1.id> and
>            id2=v2.id <http://v2.id>;
>         Ie the expect an set of objects with an id and a x and y
>         coordinate
>         In this example tmp_table functions as resource of data, and
>         the above
>         statement returns a serries of id statements id refers to id
>         of 1st x/y
>         node and the 2nd id refers to 2md x/y pair
>         eg
>         id  | id1 | id2
>              1 | 607 | 558
>              2 | 606 | 542
>              3 | 605 | 594
>              4 | 605 | 520
>              5 | 604 | 579
>              6 | 604 | 525
>              7 | 603 | 605
>              8 | 603 | 594
>              9 | 603 | 530
>             10 | 602 | 580
>             11 | 602 | 563
>             12 | 601 | 537
>             13 | 601 | 534
>             14 | 600 | 523
>             15 | 599 | 601
>             16 | 599 | 522
>             17 | 598 | 590
>         regards
>         Dave.
>         This email has been checked for viruses by Avast antivirus
>         software.
>         https://www.avast.com/antivirus
>         _______________________________________________
>         pgrouting-dev mailing list
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>     This email has been checked for viruses by Avast antivirus software.
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160325/0da2282c/attachment-0001.html>
More information about the pgrouting-dev mailing list
