[pgrouting-dev] New Releases
Vicky Vergara vicky at georepublic.de
Mon Nov 21 11:35:29 PST 2016
Hello everyone:
I am glad to announce the following releases:
*pgRouting Version 2.3.1*
   Bug fixes
   - Leaks on proposed max_flow functions
      - Regression error on pgr_trsp
      - Types discrepancy on pgr_createVerticesTable
   Read the documentation of this release at
   http://docs.pgrouting.org/2.3/en/doc/index.html
   - To see the full list of changes check the list of Git commits
   <https://github.com/pgRouting/pgrouting/commits/release/2.3> on Github.
   - To see the issues closed by this release see the Git closed issues
   <https://github.com/pgRouting/pgrouting/issues?q=is%3Aissue+milestone%3A%22Release+2.3.1%22+is%3Aclosed>
   on Github.
osm2pgrouting  2.2.0
The new documentation can be found here:
https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.2
With this release the following changes have being done:
osm2pgRouting 2.2.0
   - Adding foreign keys to the tables.
   - Added a progress bar.
   - New mapconfig_for_bicycles.xml
   - Improved the C++ code.
      - remove the use of pointers to avoid leaks.
   - Table osm_ways_tags because information is redundant.
We thank the people that contributed with pull requests, ideas, and testing.
Regards
The pgRouting team​.
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20161121/79063baa/attachment.html>
More information about the pgrouting-dev mailing list
