[pgrouting-dev] [pgrouting-users] Release of pgRouting 2.3.0(Thanks and questions about stable proposed functions)
Vicky Vergara
vicky at georepublic.de
Tue Sep 27 08:31:47 PDT 2016
Hi all:
the section:
http://docs.pgrouting.org/latest/en/src/proposedNext.html#proposednext
are basically "stable" functions. plan is to have them "official" as part
of pgRouting on version 3.0
The major reason of not being official yet, is because I am planning to
family of functions based on pgr_aStar, pgr_bdDijkstra,
pgr_turnRestrictions etc (one to one, one to many, many to many, many to
one, DD, KSP, Cost(all flavours), CostMatrix etc) and the "standard" for
the naming has not being yet decided.
Another reason, is the focus of the 2.x series is to fix all the bugs the
code has & to unify some of the "duplicated code".
Now, the reason to have them available, it gives the opportunity to people
to test, use & open tickets.
the section http://docs.pgrouting.org/latest/en/src/proposed.html#proposed
are "unstable", more unit tests and/or performance tests are needed for
pgr_contractGraph, pgr_labelGraph and the flow algorithms for example.
Hopefully for 2.4, pgr_contractGraph & flow algorithms will move to the
stable section.
Some other functions might be removed in 3.0 (like the "convinience" which
I think are "very front end focused" but more testing is to be done to
prove that statement)
In any case, issues on already rewritten functions and stable proposed
functions are taken care ASAP.
Vicky
On Tue, Sep 27, 2016 at 2:21 AM, <dave.potts at pinan.co.uk> wrote:
> !st I would like to say to Vicky and the rest of the team for getting this
> release out.
> Some proposed functions are listed e.g.pgr_dijkstraCostMatrix
> Is there any sort of timescale when they are going to be supported ,
> worked on etc.
> September 26 2016 9:12 PM, "Vicky Vergara" <vicky at georepublic.de
> <%22Vicky%20Vergara%22%20%3Cvicky at georepublic.de%3E>> wrote:
> Hello all:
> I am pleased to announce the release of pgRouting 2.3.0
> Thanks to Andrea Nardelli, and Rohith Reddy for their big effort during
> the GSoC program to incorporate new functionality for you to try: Flow
> algorithms and Contraction, all you can find under proposed functions.
> You can download and start using from
> https://github.com/pgRouting/pgrouting/releases/tag/pgrouting-2.3.0
> & packages will be ready soon.
> You can find the documentation on http://docs.pgrouting.org/2.3/
> en/doc/index.html
> Tests have being made with:
> - Ubuntu: Postgis 2.2 for Postgres 9.1, 9.2, 9.3, 9.4, 9.5
> - Windows: on 32 & 64 bits for Postgis 2.3.0dev and Postgres 9.4, 9.5,
> 9.6
> - vs1013: Postgis 2.2 Postgres 9.4
> Do not hesitate to open a new issue if you find a bug within the release.
> Thanks in advance for testing.
> pgRouting team.
> ps, was editing last mail when it got sent, please this mail is the
> correct one
> Georepublic UG (haftungsbeschränkt) Salzmannstraße 44, 81739 München, Germany Vicky Vergara Operations Research eMail: vicky at georepublic.de Web: https://georepublic.info Tel: +49 (089) 4161 7698-1 Fax: +49 (089) 4161 7698-9 Commercial register: Amtsgericht München, HRB 181428 CEO: Daniel Kastl
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160927/fa89083a/attachment.html>
More information about the pgrouting-dev
