[pgrouting-dev] boost version?
Vicky Vergara vicky at georepublic.de
Thu Sep 29 10:20:01 PDT 2016
Correction: of last answer
it reads:
I am really enforcing a minimal version on boost
should say:
I am really not enforcing a minimal version on boost
On Thu, Sep 29, 2016 at 12:13 PM, Vicky Vergara <vicky at georepublic.de>
wrote:
> Hello Devrim:
> This is the smallest boost version I tried (based on trusty default boost
> version it has)
>  Boost version: 1.46.1
> And is the "official" minimum version.
> https://github.com/pgRouting/pgrouting#requirements
> As you can see here:
> https://github.com/pgRouting/pgrouting/blob/master/CMakeLists.txt#L265
> I did try on an attempt to use boost::geometry instead of CGAL (and remove a dependency) but boost geometry appears to be in other boost version
> http://stackoverflow.com/questions/37003787/travis-ci-cant-find-boost-geometry-hpp
> So, I rolled back.
> Now, by looking at boost documentation.
> the new flow algorithms (on the experimental & proposed functions section) did exist on boost graph 1.41
> http://www.boost.org/doc/libs/1_41_0/libs/graph/doc/table_of_contents.html
> So "theoretically" I think it will work.
> Give it a try and keep me informed so I can change the "official" but not enforced (yet) minimum version.
> Vicky
> On Thu, Sep 29, 2016 at 11:09 AM, Devrim Gündüz <devrim at gunduz.org> wrote:
>> Hi,
>> I'm sure I checked this with Regina before, but forgot the answer: What
>> is the
>> minimum boost version for pgrouting 2.3.0? RHEL has 1.41, and wanted to
>> make
>> sure that it will work.
>> Can you please confirm?
>> Thanks!
>> Regards,
>> Devrim GÜNDÜZ
>> EnterpriseDB: http://www.enterprisedb.com
>> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
>> Twitter: @DevrimGunduz , @DevrimGunduzTR
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160929/9be10569/attachment.html>
More information about the pgrouting-dev mailing list
