[pgrouting-dev] GSoC 2017 - Week 1 Report - Implement Connected Components Algorithms for pgRouting by the Boost Graph Library
Maoguang Wang xjtumg1007 at gmail.com
Mon Jun 5 00:25:08 PDT 2017
Hi All,
I'm Maoguang Wang, a student particpating in GSoC 2017 (pgRouting project).
This is my weekly report for Week1 (May 30 - June 4):
*What did you get done this week?*
I discussed the signature of my new function (pgr_connectedComponentsV)
with mentors. And I used a script to generate my initial template code. I
modified and fixed this function code to suit the signature. Created a new
structure (pgr_componentV_t) instead of General_path_element_t.
Details can be found in [1].
Set of pull requests can be found in [2].
*What do you plan on doing next week?*
I plan to keep working on the template code. Also I plan to learn unit
tests in pgRouting and try to write some for my function.
Details of possible sub tasks can be found in [3]
*Are you blocked on anything?*
No, at the moment I’m not blocked.
The wiki page can be found in [4]
The repository can be found in [5]
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-
Connected-Components#week-1
[2] https://github.com/pgRouting/pgrouting/pulls?q=is%3Apr+
author%3AXJTUmg+is%3Aclosed
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-
[5] https://github.com/pgRouting/pgrouting/tree/gsoc/connectComponent
Best Regards.
Maoguang Wang
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20170605/cf4a3add/attachment.html>
More information about the pgrouting-dev mailing list
